14-07-2010, 04:41 PM #1
heat an outdoor pool/ cool a house
I have a 7 year old heat pump for my swimming pool, which is decommissioned in winter, and would like to air condition my home with a heat pump. Can I use one installation to serve both purposes?
Sorry if this answer already appears in the forum.
Thanks.
Jerry
14-07-2010, 05:01 PM #2
Re: heat an outdoor pool/ cool a house
Hi Jerry And welcome.
Basically its not a problem if the capacity is enough to cool the house.
You will have to make it a split heat pump or make ducts to deliver the cold air inside and back to the heat pump.
what will happened when the house is cold enough and the pool is still too cold? The cold air will have to be diverted out or at least warm air will have to be mixed with the cold air. And Don't forget the controls you will need.....
I think that there are too many problems will arise and eventually it will become too expensive. But that's my opinion only.
14-07-2010, 06:03 PM #3
MVHR with Heat Pump Recovery - Reduced Defrost
By Pincher in forum Heat PumpsReplies: 10Last Post: 08-03-2011, 09:21 PM -
Heat pump hot water system
By kiamaian in forum Technical SpeculationsReplies: 4Last Post: 16-06-2009, 06:48 AM -
Heat Exchanger Thermal Effectiveness
By wilsonudevil in forum Air ConditioningReplies: 1Last Post: 20-11-2008, 01:10 PM -
R134a <-> liquid heat exchanger design
By DaBit in forum Technical SpeculationsReplies: 19Last Post: 10-05-2002, 08:36 AM
