Results 1 to 11 of 11
Thread: pipes through flat roof
12-07-2010, 09:14 PM #1
Do any of you know where to get a galvanised roof cowl/riser thingy to enable pipework etc. to go straight up through a flat roof? I came across some on the net the other day whilst looking for something completely different, but cannot remember where. Need a couple for a job coming up.
Andy
12-07-2010, 09:29 PM #2
Re: pipes through flat roof
At the firm I work at we have used a product called "DEKTITE" for the situation you have said about.
They come with different diameter holes in the middle to fit around the pipes.
Type Dektite into google to see if it will meet your needs.
12-07-2010, 09:41 PM #3
No, it's not a decktite. It's a small galvanised upstand with a removable top so you can pass the pipework through and bend back down towards the roof, then put the lid back on.
12-07-2010, 10:30 PM #4
we always used to get the ducy manufacturer to knock them up andy
12-07-2010, 10:30 PM #5
that should be duct
12-07-2010, 10:35 PM #6
It's called a 'Roof-Nek' and made by 'Roof-Pro'.
Decktite's are for ducting and you will not permanently seal multiple services passing through them. ie. pipes and cables.
12-07-2010, 10:39 PM #7
Yep, that's the sort of thing. Looks a bit more expensive than the ones I'm thinking of though.
12-07-2010, 11:24 PM #8
I think the manufacturers of the big foot systems for flat roofs now do a galvanised riser for flat roofs, sorry no idea of there price.
13-07-2010, 03:59 PM #9
The Big Foot Range of "swan necks" can be found here
14-07-2010, 06:16 PM #10
I used to get a 4" or 6" roof fan casing without the fan guts somewhere. They were designed to be flashed, looked much better than something that the ducter would make up and I think were cheaper in the end. Ring a fan supplier and see if they will get a couple for you.
I can imagine some savvy entrepreneurial forum member on Dragon's Den with an idea soon...
16-07-2010, 07:04 PM #11
what about a rubber slate with galvinised flashing attached, and a length of 4 inch rain water pipe with two 45 bends (push fit) and a pot of roof repair compound to seal the "rubber slate" to the roof.
never had any complaints about leaks, from this cheap, but not very nice looking approach.
you did not say if it was a ruberoid type roof , fibreglass, or a pvc heat welded roof ie sarnafil or similar, good luck.
Fujitsu split pipes
By gazza666 in forum Air ConditioningReplies: 10Last Post: 15-07-2010, 08:59 AM -
putting services on flat roof
By b_m_services in forum Trouble ShootingReplies: 2Last Post: 17-05-2010, 05:34 PM -
Only first half of Pipes freezing?
By Bobbin in forum CommercialReplies: 6Last Post: 09-04-2010, 08:45 PM -
Another boring install thread, chucking a unit on a roof
By paul_h in forum Air ConditioningReplies: 4Last Post: 02-10-2008, 12:06 PM -
Installing pipes
By tuneee in forum FundamentalsReplies: 8Last Post: 05-06-2007, 08:21 PM
