Results 1 to 12 of 12
    thanhck's Avatar
    thanhck Guest
    operation pressure
    Dear alls,
    I would like to know how to determine the operation pressure (Low/High pressure) of a refrigeration cycle using R22 or R134a.
    At my company, we control LP/HP of air-conditioner using R22 at: 4~4.2/18~20kgf/cm2. in near future, we will change R22 to R134s, so how to control the LP/HP of refrigeration cycle? Pls help me!
    11,025
    Re: operation pressure
    Hi, do not think in pressures but in temperatures.
    Jan 2007
    India
    65
    Just check the R134a Pressure- Temperature charts and findout the LP/HP of R134a Corresponding to the R22 operating pressures/ Temperatures.
    Oct 2003
    5,630
    What do you control on the AC's with the pressures you mention?
    thanhck's Avatar
    thanhck Guest
    can you explain clearly?
    I'm a beginer so i have lot of difficult with refrigerant cycle
    Aug 2001
    Sweden
    47
    You running at -6,5 to -5 degree C evaporation and 46,5 to 51 degree C condensation. Your pressure with R134a should read 2,3~2,4/12,1~13,5 bar.
    This is your smallest problem probably, the largest is that you loose a lot of cooling power when change to a crappy refrigerant. I assume you keep your machinery.
    thanhck's Avatar
    thanhck Guest
    Quote Originally Posted by toprunner View Post
    Thanks, I'm more clearly. but temperature running of evaporator of chiller and Air conditioner are different or not?
    Aug 2001
    Sweden
    47
    Temperature will be same if your compressor is big enough.
    May 2008
    66
    802
    why the change from R22 to R134a ?
    if it is because of the fase-out, you will be better to confert to R407C, you will loose about 3% performence.
    Ice
    thanhck's Avatar
    thanhck Guest
    Quote Originally Posted by icecube51 View Post
    Ice
    My company change from chiller Mc. Quay (R-22) to chiller Trane (R134a)!!!!!
    Oct 2003
    5,630
    .....This is your smallest problem probably, the largest is that you loose a lot of cooling power when change to a crappy refrigerant. I assume you keep your machinery.
    Crappy refrigerant? Wait a year or two and you will have to change your point of view completely. R134a will become THE refrigerant for cooling and chiller applications due to its low GWP. R404a and R507c will be banned or highly taxed in the near future
    May 2008
    66
    802
    Hear Hear, spoken in truth.
    when you start to now the wonders of R134a, you never want anything else.
    Ice
  1. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  2. Pressure Increase Generated by the Compressor
    By stephen.t in forum Fundamentals
    Last Post: 06-02-2008, 07:10 PM
  3. Replies: 27
    Last Post: 27-10-2006, 03:19 AM
  4. screw compressor
    By vinod in forum Trouble Shooting
    Last Post: 17-12-2005, 01:46 AM
  5. Replies: 6
    Last Post: 18-11-2005, 04:30 PM
