Results 1 to 2 of 2
Thread: advice on 2nd hand F/F
12-07-2010, 11:36 AM #1
hi guys.
hopefully this is in the correct forum
im looking at buying a 2nd hand Fridge Freezer a zannussi about 6 year old and was around £900 when new.
could get it for £85
it seemed ok its a huge 6ft5 one.
few dings ect but nothing majour
however in the fridge the little lips that hold the shelves. normally about 10 so you can choose which ones to use.
on the very front of 2 there is a small hole where its been damaged. does this affect the function of the fridge
from what i could gather its only costmetic and to use some rvc seallant or something like that?
cheers guys
12-07-2010, 11:19 PM #2
Re: advice on 2nd hand F/F
Little holes - well it depends how old they are.
If they are in/through the plastic lining of the fridge it is possible for the insulation behind it to have soaked up lots of moisture.
This will affect the overall performance of the fridge and is a potential bacteria growing point.
The choice is yours however.Brian - Newton Abbot, Devon, UK
Techinical advice on Fujitsu AOT30RMAL?
By Taaz1275 in forum Technical DiscussionsReplies: 15Last Post: 24-06-2011, 03:35 AM -
Sea water cooler advice
By mangonui in forum Technical DiscussionsReplies: 10Last Post: 03-06-2010, 09:41 AM -
Advice on thermostat needed
By ATC@LWSK in forum Air ConditioningReplies: 2Last Post: 08-04-2010, 12:22 AM -
career advice needed
By carfy313 in forum TrainingReplies: 4Last Post: 28-03-2010, 09:17 AM -
Getting Colder, need advice
By mvtop in forum FundamentalsReplies: 54Last Post: 29-11-2009, 01:49 AM
