12-07-2010, 06:07 AM #1
Energy required to maintain 4 Deg Cel
What is the proceedure for calculating the energy required to bring down and then maintain a 1 CFT insulated space filled with water at 4 Deg Celcius, for a period of 24 hours, assuming the ambient temperature is 30 deg cel throughout the 24 hour period.
How to calculate the energy required for the above in wattage / hour - if electricity is used for a continuous cycle cooling.
and how to calculate the thermal energy required (BTU / hour) if intermittent cycle absorption cooling based heat pump is used.
12-07-2010, 08:42 PM #2
Re: Energy required to maintain 4 Deg Cel
did you have any school at all??
these are pure basics you asking.
Ice
12-07-2010, 10:51 PM #3
Energy Conservation
By US Iceman in forum Technical SpeculationsReplies: 20Last Post: 20-07-2010, 10:52 AM -
Compressing refrigerant using thermal/heat energy
By nadam54321 in forum Technical DiscussionsReplies: 0Last Post: 31-07-2009, 04:55 PM -
Energy From Oil
By DavidAdam in forum Chit Chat & Service StoriesReplies: 11Last Post: 02-07-2009, 12:40 AM -
Thermal Efficiency of Refrigeration System
By hussain316 in forum Refrigeration BooksReplies: 5Last Post: 31-07-2007, 08:59 PM -
A question about energy efficiency rating in Europe
By pcdata76 in forum FundamentalsReplies: 1Last Post: 22-05-2006, 10:17 AM
