    Apr 2001
    2,099
    27
    Fogal Open Display Case
    Model Mistral 360
    S/No 291199004
    Have a problem with this one. Unit is big around 3.5 metres
    Is seperated in half, two sections, each side has its own condensing unit
    But whole unit is operated via one Carell ir controller
    The right hand side coil iced over. Someone on site messed around with the parameters.............The system now reaches 15 celcius and stays there.
    Does not reach any lower thgen that
    The system is brand spanking new, was bought by owner from some outlet in Bournemouth which went bust.
    Hence no manuals or warranties.
    Im intrigued that both condensing units are seperate, ie: plug into seperate electric power points, yet run off one controller
    Does any member have experience of this unit? Do you have an operating manual for the Carell controller?
    Any help appreciated.
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Fogal Open Display Case
    Hi Abe,
    Can you post the controller model?
    Chemi
    Aug 2004
    Holland
    55
    HTTP://www.koeltechniek.nl.tt
    Here you wil find a lot of different manuals.
    For carel follow this link witch will take you straigt to the carel manuals.
    http://80.57.236.169/domeinnaam/docu...ory.php?cat=28
    Select your regulator, clic on it, in the next screen click on the bleu diskette symbol in the right top corner to download.
    If there is enough interest, I could translate the site into english.
    Regards victor
  1. display case evaparator fans
    By Mark in forum Supermarket Refrigeration
    Last Post: 16-01-2011, 03:03 AM
  2. Tinkering with an old Ref glass display case
    By fix_it_man74 in forum Trouble Shooting
    Last Post: 07-08-2006, 02:35 PM
  3. Need help with a dual compressor display case
    By kengineering in forum Technical Discussions
    Last Post: 15-03-2006, 07:32 PM
  4. display case temp alarms
    By shark26 in forum Supermarket Refrigeration
    Last Post: 17-01-2006, 10:07 AM
  5. Big Display Case
    By Abe in forum Commercial
    Last Post: 02-07-2003, 10:53 PM
