Results 1 to 12 of 12
    Jul 2010
    New Zealand
    5
    power consumption of freezer
    Hello,
    I have connected a household freezer up to a power meter (plugged this power meter into the mains and then the freezer into it). I have noticed that when I turn the freezer on (initial internal temperature is warm ambient temperature) the power meter reads about 120-150 W. Once it reaches steady "on/off" cycling (when the freezer is cold), the power meter reads about 100 W (during the cycle period when the compressor is on).
    I am pretty sure it is a fixed speed compressor because it operates with an "on/off" cycle, so I cannot understand why the power consumption varies.
    Does anyone have any ideas as to why?
    Aug 2009
    New Zealand
    54
    2,556
    Re: power consumption of freezer
    Quote Originally Posted by pcmdude View Post
    Hello,
    Basic principles of refrigeration!
    Aug 2008
    Baltics
    56
    786
    11
    If You still do not need to know the "basic principles of refrigeration" for Your every-day life then compare the process with, lets say: while speeding up a car and riding it at a reached steady speed - the two fuel consumption rates wil be different.
    Jul 2010
    New Zealand
    5
    Quote Originally Posted by Yuri B. View Post
    Regarding the analogy of a car, there is higher fuel consumption during accelaration due to greater fuel injection isn't it? Once a steady speed is reached, then the accelarator pedal is released a little and thus there is lower fuel injection, which gives the difference in fuel consumption rates.
    Now, regarding the freezer, if the compressor is rated at say, 240 V and 0.5A, that would mean it draws 120 W of power (can only draw 0.5 A - steady fuel injection using the car analogy). Now, the inefficiencies of the refrigeration cycle would govern how much of that power is turned into cooling power. However, since it is a fixed speed compressor, doesn't that mean it can only operate at 120 W electrical power? During cooling from ambient, the compressor runs for a prolonged amount of time, thus the energy consumption would be high (measured over a given time interval), but shouldn't the measured electrical power drawn still be 120 W at any given time? Then, when steady state is reached, the compressor switches on and off, thus the energy consumption measured over a particular time interval will be lower compared to pull down. So I understand the difference from an energy consumption point of view. But it is the difference in electrical power drawn that does not make sense to me. From my understanding (or am I wrong?) a fixed speed compressor can only run at a given electrical power (which is different from energy consumption).
    Aug 2009
    New Zealand
    54
    2,556
    The internal moter of the compressor spins a fixed speed. It drives a fixed volume piston. What changes is the mass it is moving and where it si moving to.
    On pull down it is moving a greater mass to a higher pressure elevation. Hence more work done, Work done = Power.
    Your electrical internals are not like an electric element.
    A compressor DOES NOT run at a given electrical power
    Jul 2010
    New Zealand
    5
    Quote Originally Posted by mad fridgie View Post
    Ok, thanks for that. I think I understand now.
    Aug 2008
    Baltics
    56
    786
    11
    And mass flow depends on the absolute pressures difference: the less the difference, the more mass flow and the more power consumption. So the flow is the biggest at the beginning of freezing. After a time temperature is dropping in the freezer - alongside and according to the pressure (or vice versa the pressure does alongside the temperature), the difference has increased, mass flow decreased - power consumption decreased too.
    Jul 2010
    New Zealand
    5
    Thank you Yuri B and mad fridgie for your fast and helpful responses. I really appreciate it.
    Feb 2010
    54
    243
    10
    I know you have the answer.
    But using the analogy of the car..
    Think of a car on a flat road, it uses a fixed amount of fuel to maintane a fixed speed. Now the same car drives up a hill at the same speed, it needs more power to push up the hill therefore uses more fuel..
    Fridges are the same. It is doing more work so costs more to do the work, when it achieves the corect temp the workload eases.
    All the best
    coolrunnings
    Jul 2010
    New Zealand
    5
    Quote Originally Posted by cool runings View Post
    All the best
    coolrunnings
    yup, thanks for that. I came to that same conclusion the other day when I was driving.
    JohnP's Avatar
    JohnP Guest
    If the freezer is an auto-defrost model, on startup it will go through a defrost cycle which involves a heater, before it starts freezing. The defrost lasts about 15-30 minutes, depending on model. You are probably seeing the heater power.
    Apr 2011
    India
    30
    94
    8
    Hi friends ,
    Good explanation of the refrigeration basics.Hats off to all my seniors, this website is really very beneficial for newbies like me.
  1. Power Consumption
    By cnbrazil in forum Transport
    Last Post: 28-08-2009, 07:21 AM
  2. Power consumption of Chiller
    By adrian116 in forum System Optimization
    Last Post: 24-04-2009, 05:05 PM
  3. SR2 50 models electric SBY diagonostics made simple
    By absolute-zero in forum Transport
    Last Post: 04-01-2008, 05:11 PM
  4. Daikin KRP2A61 Card Power consumption
    By EddieC in forum Air Conditioning
    Last Post: 19-08-2006, 04:08 PM
