Results 1 to 16 of 16
    Nov 2006
    At home
    181
    Yellow Jacket 18975 1/4" Core/Vacuum Charge Tool
    hi guys does anyone have experience with this type of tool, (the 18975 with the gauge port)
    http://www.amazon.com/Yellow-Jacket-.../dp/B0014JDNVO
    im liking the idea of removing schraeder to vacuum and charge, unsure how much of a difference it will make? anyone else have any opinion?
    I have charged using refrigeration back/open/front seated type service valve (king valve on the receiver if my memory serves me correctly?, could well be wrong)but cant remember how fast fast the gas went in?
    I suppose I want to know if the £30 od is worth it?
    EDIT: just realised its a 1/4" so I couldn't use it on 410a, is it possible to buy a 1/4" male to 5/16" female?
    2ND EDIT: found an adapter http://www.ryanairconspares.com/mast...ter-p-760.html incase anyone is interested, obviously not to be used on gauges not designed to take 410a pressures, couldn't be used with valve core tool mind
    11,025
    Re: Yellow Jacket 18975 1/4" Core/Vacuum Charge Tool
    Very useful tool, recently got a new one from Climate Center which included a R410a adapter.
    Yes, evacuation speed will increase, you now have a hole the size of the outside of a valve core instead a hole the size of the valve pin.
    Oct 2008
    mallorca, spain,
    75
    768
    yes skywalker they have been on the market for 30 years they are ideal for changing the scrader valve core , without de- gassing the system.
    3,856
    I've got one similar, great little tool for changing schreader cores while system is under pressure. also speeds up recovery vacing etc.
    you can get a 5/16 threaded one for 410A also.
    Feb 2008
    IRELAND
    70
    Get the 5/16 inch one. One thing the note is the 5/16 inch one has a 5/16 vacuum port on it not 1/4 inch. Its ideal to attach a vacuum gauge via a copper pipe to with no vac loss.
    Jul 2008
    london
    102
    Sorry guys but how does this work? Are you saying you can
    remove the shreader valve to vac and charge? How does this work?
    Aug 2001
    Gold Coast, Australia
    600
    28
    Get a version with a ball valve as the shut off valve. My first one was the gate valve type, and when the main seal went, no-one stocked spares! I bought a ball valve type to replace the first one, & never had a problem with it.
    Alec, that's what the tool is for. Removing the schrader (sp?) valve to make vac & charge faster.
    Jul 2008
    london
    102
    Ye but once you have put a vac on hey system how do you put the shreader back?
    Split Croatia
    57
    6,151
    36
    Jul 2008
    london
    102
    That's well good definately ordering one of them!
    Nov 2006
    At home
    181
    thanks guys, i will also be ordering one! worth the £
    Jul 2008
    london
    102
    Never seen or heard of them! But def going to order some. Will make it quicker and easier to vac/reclaim systems
    Aug 2007
    Sydney
    52
    1,083
    23
    No frigie should be without one of these, I have three of them along with all the extras like 3/8 X 6" ballvalve lines for the bigger stuff. Check them out on their web site yellow jacket (ritchie) superheat calculation kit. I now I go on about this product but I think it's one of my best tools and can speed up evacuation by 4 times faster!
    Dec 2010
    Fl,United States
    yes indeed a very efficient tool , reduces vacuum time and replacing schrader valves are a easy job .. recommend
    Oct 2007
    manchester
    5,639
    45
    javac do one for 1/4 and 5/16 ports but ive broke 2 already-by tightening onto the schraeder port u cannot unscrew it without rotating the entire tool then eventually the threads fail and u have gas rushing thru an open port! not good when the system has glo stick in and the schraeder port faces the main pcb on a 250 panasonic urban-had to jam a core in ,got burnt-lost approx 4kg of gas,and had to dry the oil off the pcb!!!javac say from overtightening!!!
    Dec 2010
    canada
    15
    Great tool, we sell about 300 of these a year, a tech's must have!
  1. Yellow Jacket 40802 and DRSA 1200
    By marc5180 in forum Tools and Calculators
    Last Post: 28-10-2009, 03:27 AM
  2. Yellow Jacket System Analyser
    By Lancelot in forum Tools and Calculators
    Last Post: 18-10-2009, 09:11 AM
  3. who sells yellow jacket tools in uk
    By TRASH101 in forum Tools and Calculators
    Last Post: 22-03-2009, 11:20 PM
  4. Yellow Jacket
    By eggs in forum Tools and Calculators
    Last Post: 14-02-2006, 09:23 AM
