    Feb 2009
    New Zealand
    38
    5
    Industrial plant maintenance
    Manufacturers of compressors used on large airconditioning or industrial plant require that their products are regularly inspected for wear.
    Could some describe the maintence checks one would do on such a plant after
    5000 hours or one year
    10,000 hours
    20,000 hours
    any help would be appreciated as i seldom work with larger plant.
    Jul 2007
    Czech
    61
    374
    Re: Industrial plant maintenance
    You must be specific.
    3,357
    Sabroe have the best advice on this in their recip & screw manuals .
    You need
    -plant conditions
    -speed
    -refrigerant type
    -type of compressor ie industrial or commercial
    Feb 2009
    New Zealand
    38
    5
    I dont have any specific data, this is a question for one of my trade papers, I asked the Senior techs at work and went through a few manuals but still dont really have what i require.
    Mar 2005
    638
    The manufacturers manuals will detail a normal maintenance schedule for the type compressor you use.
    Ken
    Mar 2010
    Dammam
    83
    15
    Yup.,usually you can see a detailed maintenance schedule on every OEM's manuals, but it really depends on what type of maintenance evolution your plant is practicing (e.g. preventive, predictive or Pro-active maintenance?.)
    For preventive in screw comps.,every 6k hrs or 1 yr. whichever comes first, we usually change oil & oil filter and checks the main drive coupling alignment.
    Every 15k hrs. or so, you can check the mech'l. seals of both comp. and oil pump for wear.
    Every 25k hrs. or 5 yrs. whichever comes first, you can check the thrust bearings, slide valve guide block and PTFE seals and replace when necessary.
    On the other side, correct operation and daily maintenance checks will make your comps. more reliable.
    <"No one is so smart, they just stay with problems longer and use their imagination">
    Feb 2009
    New Zealand
    38
    5
    thanks ref717 for your response.
    the maintenance is predictive
  1. Few question about Mitsubishi Heavy Industrial air condition
    By fireduck in forum Air Conditioning
    Last Post: 12-05-2009, 02:35 PM
  2. Industrial to Commercial
    By geoffg in forum Commercial
    Last Post: 24-08-2008, 04:46 PM
  3. Cop Of Brine Plant And Chilled Water Plant
    By patilvasudeo in forum Fundamentals
    Last Post: 16-07-2008, 06:43 AM
  4. small split maintenance charges
    By chillymatt in forum Air Conditioning
    Last Post: 20-01-2008, 07:44 PM
  5. Soap Plant Load Calculations
    By tjk2007 in forum Fundamentals
    Last Post: 25-11-2007, 05:59 AM
