Thread: Beko Frost Free - Freezing!!
Hybrid View
08-07-2010, 11:33 AM #1
Hi guys, had a Beko fridge freezer for around 18-20 months now. Last few months Ive had to keep removing the fan surround from the rear of the freezer comparment to remove frost from around the fan as the fan keeps catching it.
Ive also had to remove frost from around the back wall.
The process I have to keep repeating and its so frustrating when the fan starts catching the ice and makes a really loud noise.
Any ideas on what could be causing this - is this something a none-techy can look into prior to calling out an engineer?
Thanks in advance
Jon
08-07-2010, 11:36 AM #2
Re: Beko Frost Free - Freezing!!
Compartment*
11-07-2010, 10:11 PM #3
My FFA90 fan is the same - whirrrrrrrr thirrrr - must be the hot weather and the unit working overtime - solution - don't open the door (not much use is it!)
AEG frost free fridge
By tzs in forum DomesticReplies: 4Last Post: 03-01-2010, 06:15 PM -
beko cda543f frost free ff. Freezer does not freeze!
By benjarno in forum Trouble ShootingReplies: 3Last Post: 02-08-2009, 10:35 AM -
Beko Frost Free Fridge Freezer failing to cool
By Derek Max in forum Trouble ShootingReplies: 1Last Post: 19-06-2009, 07:31 PM -
Beko frost free freezer/fridge help needed
By DJT in forum Trouble ShootingReplies: 14Last Post: 22-12-2007, 12:13 AM -
frost free
By sashy552 in forum DomesticReplies: 1Last Post: 22-06-2007, 11:20 PM
