Results 1 to 2 of 2
05-07-2010, 10:56 PM #1
very cold Candy Fridge Freezer please help...
I have a Candy fridge freezer, about 3 years old, no model it just says 'A CLASS'.
The freezer freezes rock solid, and the fridge ices up at the back. I've got the setting on the warmest possible, just a bit higher than where it clicks off on the dial. I just need to be able to run it a bit warmer, the compressor's on nearly all the time (it does cut out sometimes) so must be costing me a lot to run. Even this weather I have to leave the ice cream to thaw for half an hour or can't use it!
I think from a previous thread, it may be the sensor. I can't see where this is though, not inside anywhere, is it buried in back insulation? can it be the thermostat if the compressor cuts out sometimes? The wires to the sensor etc, and mains lead, all go into the back centre at the top.
Can I do anything with this? otherwise it'll be off to the tip..... I'm an engineer, not refrigeration of course, but can do basic electrics too, so will have a go, last attempt to save it from landfill, but don't want to spend a lot as it's a cheap model.
Any suggestions please?
05-07-2010, 11:04 PM #2
Re: very cold Candy Fridge Freezer please help...
use a multi meter on the thermostat and see if it does break the circut when you turn it completely around to the warmest setting, I suspect the thermostat is the incorrect one or has moved from where it should be.
Maytag Freezer TOO Cold (and fridge also)
By ptb626 in forum DomesticReplies: 1Last Post: 17-08-2010, 01:56 PM -
Waeco freezer cold fridge hot
By lisney56 in forum Trouble ShootingReplies: 3Last Post: 25-12-2009, 11:43 AM -
Zanussi ZENB9950 Freezer cold fridge not
By fkarim7 in forum DomesticReplies: 3Last Post: 03-09-2009, 09:10 PM -
Frigidaire FRC150 FF - fridge not very cold freezer forming frost!!
By TriciaA in forum Trouble ShootingReplies: 3Last Post: 04-08-2009, 04:24 PM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM
