Thread: Capacitor
04-05-2005, 07:01 PM #1
Capacitor
Hi There,
Wonderin if someone can enlighten me
Fitted new compressor and capacitor today the capacitor provided was different to the older one. it was bigger in size and said 40 uf instead of 35uf which was on the old one
Fitted the capacitor and no problems with system
Just wonderin
1. what uf means
2. if it would make any difference to the system in any way??
thanks in advance
Moondawn
04-05-2005, 07:25 PM #2
Re: Capacitor
uf = micro farad
if it's a little bit bigger , that's ok , the system will work normallyEngineering, sciences, math, physics and my brain will generate "not responding " soon
04-05-2005, 08:00 PM #3
Re: Capacitor
Capacitors are rated by microfarads (uf) and voltage. The rated capacitor should not be
changed, since the motor operates at maximum efficiency when using a specified
capacitor size. Although a plus or minus 10 % rule of thumb applies to the microfard rating
when changing out a capacitor. If necessary, the replacement capacitor voltage rating can
be higher than specified, but not lower without effecting the capacitor life.Engineering, sciences, math, physics and my brain will generate "not responding " soon
05-05-2005, 07:41 PM #4
Re: Capacitor
Thanks botrous for your input made things a lot clearer
Moondawn
05-05-2005, 07:55 PM #5
Re: Capacitor
welcome monndawn , hope u r enjoying the forum
Why a capacitor on contactor coil
By wambat in forum ElectricalReplies: 18Last Post: 15-05-2009, 03:18 AM -
Sizing of Capacitor bank
By Kevin Yeo in forum FundamentalsReplies: 9Last Post: 28-03-2009, 06:08 AM -
what is a capacitor power pack ?
By Bahaaeldeen in forum Air ConditioningReplies: 2Last Post: 11-05-2006, 12:56 PM -
run capacitor??
By t-bone in forum Trouble ShootingReplies: 5Last Post: 16-04-2006, 03:48 AM -
Capacitor query
By Coolie in forum Trouble ShootingReplies: 14Last Post: 05-11-2004, 06:35 AM
