03-07-2010, 11:56 AM #1
Samsung fridge/freezer model RSH1DTMH
Can anyone tell me what the temperature settings should be for the fridge and freezer please?
03-07-2010, 10:52 PM #2
Re: Samsung fridge/freezer model RSH1DTMH
Fridges usually run at 2-6 deg C, freezers usually run at minus 23-minus 18 deg C.
15-07-2010, 09:04 AM #3
By 'settings' I presume you mean, what temperature should you set the appliance to ?
My advice would be 4 deg. for the fridge and -18 deg. for the freezer.
The manufacturer gives you a choice to adjust either cabinet if you feel either the fridge or freezer is not cold enough or too cold as the case may be. The machine will work to whatever you select but be aware the lower the temperatures you select the more power it will use !!
30-07-2010, 12:15 AM #4
I have a samsung myself, the default settings, are 3 for fridge and -21 for freezer
