Thread: Freeze-Up Thermostat ?
02-07-2010, 11:18 PM #1
I was hoping someone might be able to tell me a little bit about a freeze up thermostat? What it is, where you'de install it, how you'de set it up etc.
It's a question I've had come up in some of my book work, and have had no luck finding information about it anywhere!
Any help would be appreciated.
02-07-2010, 11:32 PM #2
Re: Freeze-Up Thermostat ?
In relation to an air handling unit you would normally have a "frost stat" just after the first heating coil in the unit.
If the heating water was unable to maintain the required minimum off-coil temperature then the stat would operate and switch off the fan to stop the airflow over the coils.Brian - Newton Abbot, Devon, UK
24-03-2011, 08:24 AM #3
Joe you sneak RFLMAO
24-03-2011, 09:16 AM #4
Hi ozzy_joe and a big welcome to our forum.
What is your application for the freeze up tstat? Is it like a post mix machine for coke or beer? or is it something else, refrig or ac?
You av a strange name for some one in Kiwi land calling your self ozzy, so are you a Kiwi or a Kangaroo? - I'm a Kiwi who lives and works in Kangaroo land and love it.
Defrost thermostat puzzle
By 4hal in forum Heat PumpsReplies: 1Last Post: 25-05-2010, 11:34 PM -
Fridge Thermostat replacement
By LucasAdamson in forum ElectricalReplies: 6Last Post: 30-11-2009, 12:14 PM -
Thermostat
By hahung in forum Air ConditioningReplies: 10Last Post: 10-01-2009, 03:49 PM -
VRV & Thermostat
By hahung in forum Technical DiscussionsReplies: 0Last Post: 08-01-2009, 08:59 AM -
Change BRC1D528 for X10 Thermostat
By creible in forum Air ConditioningReplies: 5Last Post: 07-01-2008, 09:35 PM
