    MelbourneEngg's Avatar
    MelbourneEngg Guest
    Low speed Variable Speed Screw Chiller
    I was wondering what is the lowest speed that the compressor can go to on a variable speed screw chiller before the inlet guide vanes start to kick in. i assume it to be somewhere around 50% of Full Load speed but not sure.
    Does this speed change at different conditions or with different manufacturers?
    3,355
    Re: Low speed Variable Speed Screw Chiller
    In general minimum speed on most makes is 1440rpm .
    This is because of rotor tip speed and sealing against casing .
    Mar 2006
    Merate (LC) - Italy
    2,549
    No inlet vanes in screw compressors
    Somerset
    69
    4,698
    Quote Originally Posted by NoNickName View Post
    Thanks NNN,
    I was reading the post and thinking "Is it me" surely Inlet guide Vanes applies to Centrifs?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Thanks NNN,
    Exactly. Surely the lowest limit in screws is the highest discharge temperature for the reduced flow.
  1. Variable speed motor theory help
    By Contactor in forum Electrical
    Last Post: 17-05-2010, 05:24 PM
  2. Replies: 14
    Last Post: 27-01-2010, 02:32 AM
  3. LG heat pump problem
    By back2space in forum Heat Pumps
    Last Post: 01-02-2009, 11:23 PM
  4. York Screw Chiller How low will it go?????
    By bruceboldy in forum Industrial Compressors
    Last Post: 10-08-2007, 10:29 PM
  5. Variable speed screw compressors
    By Friobernal in forum Industrial Compressors
    Last Post: 14-11-2004, 09:28 AM
