Thread: Carrier Puron
01-07-2010, 12:48 PM #1
Carrier Puron
hello everyone,
I've taken on a new site that has a Carrier Puron condensing unit Model No 30RA013-9B. The unit is connected to a AHU.
At present I am unable to run the unit.
The unit does not have a controller attached in any way, all the connnections for a controller are cable free.
can these units run as a stand alone unit? are controllers not necessary? The customer has said that the unit has never seemed to work properly.
can you help me guys?
01-07-2010, 05:58 PM #2
Re: Carrier Puron
The 30ra has an optional prodialog controller, theunits without are operated by an external source controlling setpoint if i were you id recomend to the customer to have a control fitted it makes life a lot easier
01-07-2010, 11:02 PM #3
Re: Carrier Puron
30RA documentation is here if you want it...
http://eto.carrier.com/lit.aspBrian - Newton Abbot, Devon, UK
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
Carrier Chillers
By Ed Burris in forum Technical DiscussionsReplies: 6Last Post: 27-03-2010, 02:00 AM -
Geoff in NY ~ Carrier Parts
By Futsal1st in forum Trouble ShootingReplies: 6Last Post: 30-12-2009, 04:07 AM -
Help identifying carrier HiWall dom. split
By paul_h in forum Air ConditioningReplies: 4Last Post: 12-12-2008, 09:12 AM
