Thread: rhoss error
    iceman zl's Avatar
    iceman zl Guest
    rhoss error
    hi everybody
    im new in this forum
    im having e problem with e rhoss chiller CWA\E 70
    here is the situation . the unit has 4 compressors and only 2 are running and on display gives E 22 error
    anyone any idea what s going wrong
    thanks in advance
    May 2010
    44
    Re: rhoss error
    I'd start with the basics. Manufacturer data should tell you what error 22 might indicate, then check those first. Next I'd check for voltages at the contactor and contactor coils.
    May 2008
    803
    10
    Re: rhoss error
    check for high or low pressure on that circuit.
    Ice
    iceman zl's Avatar
    iceman zl Guest
    Re: rhoss error
    thank you guys for your suggestions i really appreciate this but i think im gonna need e rhoss manual for cwa/e 70 model . has it anybody
    thanks again
    frode74's Avatar
    frode74 Guest
    Re: rhoss error
    Low pressure circuit 2
    Oct 2003
    56
    5,519
    28
    Re: rhoss error
    Indeed LP for Circuit 2 and you need to switch off power to the controller to reset this.
    Lack of gas (don't overcharge because there's no receiver) or lack of load or TEV fault.
  1. shining fault codes
    By al in forum Air Conditioning
    Last Post: 17-07-2010, 08:34 AM
  2. Daikin BRC1C51 Error code help
    By monners in forum Trouble Shooting
    Last Post: 02-11-2009, 11:03 PM
  3. which compressor is the best?
    By cakabo28 in forum New Technologies
    Last Post: 19-08-2009, 06:44 PM
  4. Angelopo Sm2l Error E2 Please Info About This Error
    By CHARLIEZOLO in forum Commercial
    Last Post: 22-12-2005, 03:47 AM
