Results 1 to 2 of 2
Thread: Liebherr Fridge fault code F0
30-06-2010, 01:13 PM #1
Hi Everyone,
I am trying to fix a Liebherr frost free Fridge. The fridge will not cool down on normal settings. If I put super cool on it works fine. I have changed the temperature probe and the circuit board and it still will not work. It doesn,t make any sense. There is no other sensors connected but the circuit board will not output power to the compressor unless on super cool. The display when first switched reads fault code FO. The model number is 0971714-00. Any help would be appreciated.
Mike C
01-07-2010, 09:24 PM #2
Re: Liebherr Fridge fault code F0
If this model has a biofresh compartment, error F0 is biofresh air sensor failure
Hoover VCN6185 E1 Fault code fridge warm freezer frosting ?
By Ronnie in forum DomesticReplies: 7Last Post: 15-01-2010, 12:58 PM -
Liebherr biofresh fridge freezing up
By jimbo42 in forum DomesticReplies: 2Last Post: 17-09-2009, 08:24 PM -
LIEBHERR Frost Free fridge
By Lucas in forum DomesticReplies: 9Last Post: 30-09-2008, 09:07 PM -
Liebherr Fridge Freezer fault
By bedroom fitter in forum DomesticReplies: 3Last Post: 21-01-2008, 01:21 AM -
mitsubishi city multi fault code
By robin r33 gtr in forum Air ConditioningReplies: 5Last Post: 05-11-2007, 10:23 PM
