    Mike C's Avatar
    Mike C Guest
    Liebherr Fridge fault code F0
    Hi Everyone,
    I am trying to fix a Liebherr frost free Fridge. The fridge will not cool down on normal settings. If I put super cool on it works fine. I have changed the temperature probe and the circuit board and it still will not work. It doesn,t make any sense. There is no other sensors connected but the circuit board will not output power to the compressor unless on super cool. The display when first switched reads fault code FO. The model number is 0971714-00. Any help would be appreciated.
    Mike C
    May 2008
    U.K.
    73
    Re: Liebherr Fridge fault code F0
    If this model has a biofresh compartment, error F0 is biofresh air sensor failure
  1. Replies: 7
    Last Post: 15-01-2010, 12:58 PM
  2. Liebherr biofresh fridge freezing up
    By jimbo42 in forum Domestic
    Last Post: 17-09-2009, 08:24 PM
  3. LIEBHERR Frost Free fridge
    By Lucas in forum Domestic
    Last Post: 30-09-2008, 09:07 PM
  4. Liebherr Fridge Freezer fault
    By bedroom fitter in forum Domestic
    Last Post: 21-01-2008, 01:21 AM
  5. mitsubishi city multi fault code
    By robin r33 gtr in forum Air Conditioning
    Last Post: 05-11-2007, 10:23 PM
Tags for this Thread
