30-06-2010, 11:02 AM #1
mcquay chiller model hsa205q127ya
does anyone know why this unit would be intermittantly cutting out on pressure differential fault, always at 12 degrees celcius leaving water temperature.
30-06-2010, 12:50 PM #2
Re: mcquay chiller model hsa205q127ya
It can't get the suction pressure down quick enough so throttle suction or liquid line to get away or install an mop valve.
The Bridge Keeper
'Answer me these questions three, n'er the other side ye see.'
What is your name?
What is your favourite colour?
What is your suction superheat?
30-06-2010, 11:05 PM #3
Chilledright,
Like HallsEngineer said suction pressure most likely to high. Check your load solenoid and your loading pulse rates, may need to quicken up the loading. What is the chiller model no? The number you have posted is the compressor model no.
Mcquay Chiller problem
By hitmanzak in forum Trouble ShootingReplies: 31Last Post: 24-11-2010, 03:39 PM -
McQuay Chiller help.
By sean in forum Technical SpeculationsReplies: 3Last Post: 17-05-2010, 03:04 PM -
McQuay Chiller Problem
By philpsy in forum CommercialReplies: 8Last Post: 14-05-2010, 02:52 PM -
Problem with mcquay chiller
By texanul in forum IndustrialReplies: 6Last Post: 04-02-2010, 08:51 PM -
McQuay chiller tripping
By moideen in forum Trouble ShootingReplies: 1Last Post: 09-05-2008, 11:19 AM
