Thread: Chiller to AHU Pressure Problem
30-06-2010, 06:39 AM #1
hi Friends.
i have pblm with my chiller to ahu Pressure
My Chiller Standing at 3rd floor CHWS 50 Psi Pressure. my ahu standing at basement floor.
actual way chilled water supply Psi + Gravity needed to b.f ahu return, but i am getting only 15 psi what is the pblm?. Please Help me..................
30-06-2010, 11:05 PM #2
Re: Chiller to AHU Pressure Problem
1st problem, you are writing in shorthand, makes it hard to read and understand.
Loss of pressure could be due to:-
Is the pipe sizing correct?
Is the pump running?
Is the pump rotation correct?
Are all of the valves open?
Is the water clean?
Are there any blockages in the system?Brian - Newton Abbot, Devon, UK
01-07-2010, 03:10 AM #3
01-07-2010, 01:49 PM #4
You will always get system losses.
I would be more concerned if the flow rates weren't correct as this would lead to a loss of duty
02-07-2010, 05:51 AM #5
is this a new plant or an old one that has this trouble for the first time.
some more history will help us to understand the situation, and will give better possible solutions for youre problem.
Ice
04-07-2010, 05:32 PM #6
hello dear
you check ur waterpump inlet strainer. all valves.
Chiller connectivity problem
By ALLAHHOOPK in forum New TechnologiesReplies: 2Last Post: 12-05-2009, 05:57 PM -
Chiller tripping Problem
By bhasadu in forum Trouble ShootingReplies: 0Last Post: 21-06-2008, 09:12 AM -
R11 Centrifugal Chiller Oil Problem
By iceman007 in forum Trouble ShootingReplies: 8Last Post: 17-02-2008, 02:14 AM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM
