    a4anoop's Avatar
    a4anoop Guest
    Oil Temperature -Trane Chiller
    Dear all
    We are having Centrifugal Water Chiller of Trane using HCFC -123 as the refrigerant . We are facing a problem with the Oil Heater. The temp is not raising above 90 F it should be above 140 F.We tried replacing the heater but still didnt worked , Checked the thermowell .Everything is working fine except the Oil temp . What could be the possible reason for this
    Aug 2007
    Sydney
    1,083
    23
    Re: Oil Temperature -Trane Chiller
    I had a similar problem on an older carrier centrif - it turned out to be the thermostat.
    Apr 2009
    israel
    778
    hi u should check the settings of the controller.it might be set to low!!!as said before.
    and make sure when unit is stopped that there is no water flow through the condenser.
    good luck
    THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
  1. Trane chiller Training
    By sefuss in forum Training
    Last Post: 26-05-2010, 05:01 PM
  2. Trane chiller HP fault
    By Kirky in forum Air Conditioning
    Last Post: 19-05-2010, 08:39 PM
  3. Trane chiller problem
    By dannycool in forum Air Conditioning
    Last Post: 08-04-2010, 11:31 PM
  4. NVQ 3 online test
    By Burrah Boy in forum Training
    Last Post: 28-10-2009, 08:35 PM
  5. Trane CVHE 450 R11 Centrifugal Chiller
    By albertjoseph in forum Air Conditioning
    Last Post: 06-10-2008, 03:23 PM
