Results 1 to 1 of 1
Thread: rs21 freezing up again
29-06-2010, 11:24 PM #1
hi
my rs21 has had the samsung recall and new parts fitted
the evaporator heater failed after 13 months and samsung did'nt want to know
fitted a new evap heater and defrost sensor and the unit worked fine
now it is icing up again but this time around the tray heater at the bottom of the unit
i've tested the heaters for resistance and they seem ok the defrost sensor reads 6.9Kohms and the thermal fuse is ok
spent a lot of money on repairs and i'm tempted to buy a new unit
any ideas what the problem could be
i suspect the tray heater is faulty
best regards
Quick freeze in brine solultion vs blast freezing seafood??
By lhwang78 in forum CommercialReplies: 9Last Post: 19-06-2010, 04:48 AM -
Quick freezing of fresh products
By maxim971 in forum Technical SpeculationsReplies: 12Last Post: 18-09-2009, 11:06 PM -
Freezing Time
By M.JAFARI in forum Technical DiscussionsReplies: 1Last Post: 22-11-2006, 07:05 PM -
Freezing problem
By MajinDave in forum Trouble ShootingReplies: 10Last Post: 15-07-2006, 12:01 AM
