Thread: Copper multi-port tubes
26-06-2010, 05:09 AM #1
Multi-port copper tubes have been developed over the past few years.
These can come in a number of variants:
1. Formed-then-finished all-in-one construction;
2. Composite construction - internal insert fitted inside tube & joined.
The type2 construction has pressure capability typically of up to around 38bar(g) & can be constructed from copper & its alloys (brass). The typical joining method for the internal insert is generally brazing.
The type1 construction has been tested to 320 bar(g), where the test pump failed. These tubes can be used in CO2 applications, with ease, due the typically small grain size of copper & its alloys. Examples of shapes vary from a series of tubes joined side-by-side, to a flat 16x1.5mm 4-port multiport tube, to junctions of tubes of different diameters.
I'm very interested in getting these type2 tubes moving in the RHVAC industry & would like to brainstorm uses for these tubes in the current RHVAC industry. I'd really value comments & suggestions, wish-lists. Wherever an aluminium multiport tube enters the RHVAC industry, it can be out-performed by these new copper-based tubes. I understand copper to be the natural material of choice for the RHVAC industry.
An application for the use of a flat multiport tube could be in condensers, or evaporators, for example.Last edited by desA; 26-06-2010 at 05:13 AM.
26-06-2010, 10:15 AM #2
Re: Copper multi-port tubes
Thanks dESA
How about a heat exchanger for hot water heatpump or water to water exchanger. Provided pressures are not to different a very thin wall could be used - How thin is the wall thickness of these tubes? and what is their U value? Could you please give us some specks and maybe some pics.Last edited by Tesla; 26-06-2010 at 10:16 AM. Reason: Typo
26-06-2010, 12:11 PM #3
Desa
If the tube is only rated to 38B how would it be suitable for RHVAC?
al
27-06-2010, 02:41 AM #4
There are two types of tube:
Type1 - burst pressure ~ 38bar(g)
Type2 - burst pressure > 320bar(g).
These tubes are of totally different construction. The type1 tube is what we call a composite tube, where an insert is placed inside a thin-walled tube, then the whole composite tube fused together.
38bar would be sufficient for a heat-pump system running on R134a, R407c, R290 for instance.
For cases where higher pressures are required eg. R410A, R744, then the type2 tube - with burst pressure in excess of 320bar(g) should be used.Last edited by desA; 27-06-2010 at 02:54 AM.
27-06-2010, 03:14 AM #5
Good ideas, Tesla. Thank you.
For comparison purposes, the multiport tube construction used in typical aluminium automotive condensers (R134a) has a wall thickness of ~ 0.2mm - 0.3mm - due to the large aluminium grain size. With copper, or brass tubes, the grain size is very refined, allowing greatly reduced wall thicknesses, for similar, or better corrosion resistance.
R,th = dx/k
where : dx = material thickness [m] / k = thermal conductivity [W/m.K]
U,th = 1/R,th = k/dx
Example : copper k ~ 380 W/m.k ; dx = 0.1e-3 m
U,th = 380/0.1e-3 = 3,800,000 W/m2.K !!!
In other words - negligible thermal resistance.
Could you please give us some specks and maybe some pics.Last edited by desA; 27-06-2010 at 03:42 AM.
copper infection?
By majo in forum Technical SpeculationsReplies: 6Last Post: 29-08-2009, 03:35 PM -
joining copper to copper, joining copper to brass
By mac_J in forum Technical DiscussionsReplies: 9Last Post: 15-01-2008, 02:29 AM -
What kind of tubes to use???
By Sanel in forum FundamentalsReplies: 7Last Post: 05-01-2007, 01:03 PM -
reduce thickness of bended copper tubes
By rlim in forum Air ConditioningReplies: 4Last Post: 08-07-2003, 10:58 PM -
Balanced port TEVs
By Prof Sporlan in forum FundamentalsReplies: 22Last Post: 25-02-2002, 03:43 PM
