    Nepal
    Question Cold room insulation
    Has any one used waterproof plywood board as insulation inside a cold room where temperature maintained is always above 32 F (0 Celcius)
    Jun 2010
    Wales
    Re: Cold room insulation
    Personally no but i wouldn't really suggest it either. Wood is quite permeable, & wood doesnt really contain any insulation properties. Stick to what you know and use the proper insulation.
    thanks
    Mar 2008
    232
    Quote Originally Posted by Rabindra View Post
    Well as some one who has been around a bit in this business the only time I remember seeing plywood used was about 30 years ago when a company called BUSS made apple stores from bonded plywood to polyurethane panels, that is plywood on both inner and outer skins.
    Don't know if that helps you but yes it has been used but not as an insulation just as a structural skin for the cold store.
  1. Cold Room Pressure
    By Lauren in forum Technical Speculations
    Last Post: 25-06-2010, 01:50 AM
  2. Insulation for Cold Room
    By tjk2007 in forum Fundamentals
    Last Post: 19-03-2010, 02:54 AM
  3. Blind Cold room specs help
    By frostedflake in forum Trouble Shooting
    Last Post: 13-03-2009, 01:49 AM
  4. Installation of cold room
    By Josip in forum Legal-Business-Marketing
    Last Post: 12-03-2006, 09:20 PM
