Thread: Cold room insulation
24-06-2010, 10:13 AM #1
Has any one used waterproof plywood board as insulation inside a cold room where temperature maintained is always above 32 F (0 Celcius)
27-06-2010, 04:35 PM #2
Re: Cold room insulation
Personally no but i wouldn't really suggest it either. Wood is quite permeable, & wood doesnt really contain any insulation properties. Stick to what you know and use the proper insulation.
thanks
27-06-2010, 06:27 PM #3
Well as some one who has been around a bit in this business the only time I remember seeing plywood used was about 30 years ago when a company called BUSS made apple stores from bonded plywood to polyurethane panels, that is plywood on both inner and outer skins.
Don't know if that helps you but yes it has been used but not as an insulation just as a structural skin for the cold store.
Cold Room Pressure
By Lauren in forum Technical SpeculationsReplies: 31Last Post: 25-06-2010, 01:50 AM -
Insulation for Cold Room
By tjk2007 in forum FundamentalsReplies: 25Last Post: 19-03-2010, 02:54 AM -
Blind Cold room specs help
By frostedflake in forum Trouble ShootingReplies: 5Last Post: 13-03-2009, 01:49 AM -
Installation of cold room
By Josip in forum Legal-Business-MarketingReplies: 12Last Post: 12-03-2006, 09:20 PM
