Thread: Pump Alignment
    cspenard's Avatar
    cspenard Guest
    Pump Alignment
    In the next week I am going to have to align the 3 chilled water pumps for the new Trane screws my company just installed. Problem is, it's been ages since I've done one and I want to do it the correct way, not just use a straight edge. My company also doesn't have 5K to drop on a laser tool, so any advice or direction to a good alignment website would be appreciated.
    Jul 2006
    74
    865
    26
    Re: Pump Alignment
    Laser tool not needed! A dial indicator does well.
    Look up this link and it will tell you all you need to know.
    http://www.carlylecompressor.com/Fil...ent_lowres.pdf
    Aug 2007
    Sydney
    52
    1,083
    23
    Re: Pump Alignment
    Thanks NH3LVR
    I d.loaded and checked it out and it's a goodie.
    Apr 2008
    215
    Re: Pump Alignment
    Great book, thanks NH3LVR..
    Sep 2008
    427
    Re: Pump Alignment
    Great reference book, thanks very much.
    Jan 2006
    Norway
    1,044
    4
    31
    Re: Pump Alignment
    Very nice NH3LVR!
    But a small tip, always ALWAYS! allign the machine sideways before you check the height.
    if the machine is off sideways, they height will be off as well.
    When I align machines, the first thing I do is make them parallel, even if they are off center.
    when they are parallel I move the motor sideways and try to keep it within the parallel as I move it sideways.
    Once you have the motor clocked in within the sideways tolerance you can start worrying about the height.
    -Cheers-
    Tycho
    cspenard's Avatar
    cspenard Guest
    Re: Pump Alignment
    Thanks for the advice and thanks for the link NH3LVR it's very much appreciated.
  1. liquid ammonia pump calvitation
    By Kathleen in forum Trouble Shooting
    Last Post: 20-05-2011, 02:18 AM
  2. Addition of a heat pump to solar heating system
    By rt29781 in forum Heat Pumps
    Last Post: 23-01-2010, 08:46 AM
  3. Replies: 14
    Last Post: 27-08-2008, 08:57 PM
  4. Troubleshooting a vacuum pump and gauge set.
    By Old Codger in forum Fundamentals
    Last Post: 08-08-2008, 05:13 PM
  5. frostles heat pump
