Thread: Vessel REEFER
22-06-2010, 01:53 PM #1
Vessel REEFER
Hello Guys, I am new to refrigeration and much interested in reefer vessel. Can you please share your ideas how the system works.
The vessel I am working composed of 3 units 60 KW Yashegawa compressor, 4 blast freezer, Storage room ang RSW.
Cheers,
Johni
26-06-2010, 10:13 AM #2
Re: Vessel REEFER
may be Hasegawa compressors ? I'm russian reefer engineer and I work on vessels. What are you interesting ?
26-06-2010, 01:35 PM #3
Re: Vessel REEFER
Thanks mate your there.. Yes, its hasegawa compressor. The vessel im working is a 339GT reefer, a second hand from Japan and used in the Philippines. The system is always flooded and there is an oil inside the evaporator coil, recently we drain the oil by cutting the coil and used nitrogen inside the evap coil. How to avoid the oil from entering to the system? What is the right procedure in draining oil inside the evaporator coil? Thank you again.. Johni
26-06-2010, 02:43 PM #4
Re: Vessel REEFER
is it ammonia or halocarbon refrigerant?if possible attach a drawing so we could help you further on your query.
abet
30-06-2010, 10:06 AM #5
Re: Vessel REEFER
Its an R-22 ***** refrigerant, I will try post here the drawing. Thanks
Help cutting open 40ft reefer, we now have problems
By adrian_uk17 in forum IndustrialReplies: 50Last Post: 28-11-2010, 09:11 AM -
Reefer Tecnnichian Training
By cnbrazil in forum TransportReplies: 4Last Post: 15-08-2009, 04:41 PM -
Dry suction of one vessel into the wet of another!
By I LUV NH3 in forum NH3Replies: 0Last Post: 14-05-2008, 05:05 PM -
Parker levels in ammonia systems
By Friobernal in forum IndustrialReplies: 3Last Post: 04-08-2005, 03:46 PM
