    Apr 2004
    Pakistan
    44
    131
    :rolleyes: capillary tube size in distributor?
    Hi there
    Actually my question is that we use expansion valves in DX coils and for larger coils distributors are used with capillaries (each capillary making its own circuit).
    Now my question is how much length of capillary to be used in Distributor? as Thermostatic expansion valve is already there
    What effect this capillary makes on expansion and what effect will it have on selection of expansion valve.
    Our nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
    Mar 2005
    58
    110
    Re: :rolleyes: capillary tube size in distributor?
    Dear abbasi,
    Try this link:
    http://rc.danfoss.com/TechnicalInfo/...1/RD1CB102.pdf
    It is the technical leaflet for Danfoss refrigerant distributors. It shows the relation between capacity (of a section of the evaporator), the tube diameter, the evaporating temp. , the pressure drop and the length of the distributor tube.
    Jun 2006
    India
    63
    28
    These are not, in fact, the capillaries ( and does not act like capillry) which you see with distributor. They are provided to ensure the metered flow of Lp liquid equally to all the circuit of the coil.
    It is adviced to keep the equal length of all the tubes of the distributor to the coil.
    Length of the tube is more an approach criteria and less the design one.
  1. size capillary for any application & refrigerant
    By benijoseph in forum Technical Speculations
    Last Post: 07-06-2009, 10:00 AM
  2. Capillary tube prices in the UK
    By trial in forum Fundamentals
    Last Post: 18-09-2007, 12:16 PM
  3. metric capillary tube
    By tralex in forum Fundamentals
    Last Post: 21-02-2006, 07:57 AM
  4. Superheat in Capillary tube systems
    By setrite in forum Technical Speculations
    Last Post: 20-06-2002, 12:08 AM
