    pixie_cambino's Avatar
    pixie_cambino Guest
    Citroen C5 air con dead
    Hi folks, wondering whether anyone out there will be able to help. The ac on the car hasnt been performing too well for a while, a kwik fit recharge seemed to help slightly (dont believe they tested for leaks but cant be sure) and then after a long drive, with the ac on, from under the bonnet there came a noise like a scalded cat, then silence. Now absolutely no ac (dont feel it kick in like I used to - was that a good thing?).
    So, can anyone
    a). Give an idea of what the fault may be (am prepared for the worst)
    b) Recommend any car air con specialists in the Reading (UK) area that may be able to help
    Thanks in advance
    Somerset
    69
    4,713
    Re: Citroen C5 air con dead
    It's likely from what you describe that if lucky your compressor drive belt has failed.
    Or could even be missing if unlucky your compressor may have failed.
    What have Kwickfit said?
    Jul 2008
    uk
    150
    kwik fit was your first mistake, send a message to Clk320_Greg he maybe able to sort you out if your local to him
    Jun 2010
    41
    **** fit more like, wouldnt trust them to fit a bulb!!!can bet they didnt check for leaks, best left to a pro!
  1. Daikin indoor unit totally dead :(
    By craigix in forum Heat Pumps
    Last Post: 24-11-2009, 06:40 PM
  2. What happens to dead penquins ?
    By Brian_UK in forum Chit Chat & Service Stories
    Last Post: 30-10-2009, 12:50 AM
  3. Cold Room Dead Spots and thermometer readings
    By tudorice in forum Technical Discussions
    Last Post: 21-10-2009, 09:54 PM
  4. Dead load & live load for PU Panels
    By tjk2007 in forum Technical Discussions
    Last Post: 31-07-2009, 05:07 AM
  5. One Dead In McDonald's Air Con Explosion
    By LRAC in forum Air Conditioning
    Last Post: 19-09-2007, 01:18 AM
