    moswald's Avatar
    moswald Guest
    Phase change project - need advice.
    Hello,
    I am currently using a phase change CPU cooling system.
    My current compressor and condenser is good for about 250 watts.
    I am upgrading CPU's to a setup that will require upwards of 500 watts of cooling (possibly more).
    I also want to run a 220v-240v compressor for power consumption reasons.
    I was thinking about this setup:
    Danfoss SC12G
    A new 17" x 16" condenser and 12v fan from a BMW e36.
    I figure my condenser should be able to shed up to 1500 watts.
    This compressor says r143a, but is there a better choice?
    Am I on the right track?
    Suggestions?
    Thanks!
    69
    10,444
    Re: Phase change project - need advice.
    Correction if I may, the compressor is rated for R134a and -35C evaporating temperature.
    Don't forget to keep the compressor in the inlet side of the condenser fan and to pipe up the oil cooling circuit.
    May 2010
    uk
    59
    7
    What cpu are you going to use that puts out 500w ?
    Most peeps when building for 300w+ would be charging with r507 when using in a single stage. It runs at high pressure though, so care needs to be taken.
    Jul 2010
    usa
    33
    your thinking is really great and thanks for your post
    Aug 2001
    Sweden
    56
    47
    Will you dump 1500W of heat inside your office? Dont you think a outdoor unit will be better.. at least for summer use?
    Belgian_Brewer's Avatar
    Belgian_Brewer Guest
    wow... what a thought, a separate condenser sitting outside, right next to the house AC, just for the computer.
    also, 134a is the only refrigerant you can get without an EPA license.
  1. Three phase motors (project)
    By zeevalentino in forum Electrical
    Last Post: 10-03-2010, 04:16 AM
  2. Capillary Tube Characteristics
    By Chef in forum Fundamentals
    Last Post: 10-03-2009, 02:03 PM
  3. Career Change Advice. R&D to Installation.
    By artie fufkin in forum Training
    Last Post: 31-08-2008, 06:45 PM
  4. CO2 phase change video
    By US Iceman in forum CO2
    Last Post: 12-04-2008, 12:52 PM
  5. SR2 50 models electric SBY diagonostics made simple
    By absolute-zero in forum Transport
    Last Post: 04-01-2008, 06:11 PM
