20-06-2010, 10:21 PM #1
Freezer room door heater kit needed
Hi all
Can someone recommend a good door heater kit for a freezer room.
I have got a kit in the past that comes in 2 sections you put on the bottom part then thread around the white heater wire then screw on the aluminium cover but its not very easy,
Chris
21-06-2010, 06:11 AM #2
Re: Freezer room door heater kit needed
What type of door is that ?
The door could be with 3 side frame - i.e. inside / outside floor levels same & other type is 4 sided frame. 4 sided frame heaters are easy to fit.
Every manufacturer shall have different methods of fixing of these heaters.
21-06-2010, 08:14 AM #3
I need a 4 sided frame heater kit
Maneurop MT51HK4A - Freezer Room
By Hatchy in forum Trouble ShootingReplies: 35Last Post: 09-08-2010, 12:10 PM -
freezer room equipment
By jack smith in forum Tools and CalculatorsReplies: 4Last Post: 12-06-2010, 05:27 AM -
Cold room/ Freezer combo.
By dogma in forum CommercialReplies: 14Last Post: 09-11-2008, 02:25 PM -
Misa Kit Freezer Room
By Abe in forum CommercialReplies: 2Last Post: 03-01-2007, 09:04 PM -
Freezer Room Panels
By Feeze in forum Technical DiscussionsReplies: 10Last Post: 22-04-2005, 05:58 AM
