    Jun 2009
    United States
    45
    34
    Imeco evaporator
    It's me again looking for help here. I have a plant with Imeco evaps on a dock. Recently one of them was spraying water from all three fans. I went up in a lift and looked through the fans, off of course, and saw a decent amount of debris in the pan under the coil. When I went over to the drain pan bottom where the trap is pipped, with the fans off condensate ran down nicely to the drain. This probably due to the fact that when the fans were off I eliminated the negative pressure from the fans the water flowed freely. Without a thought I decided to bend up the sheet metal that seperates the main drain pan from the last section where the trap is. Put the unit back into operation and NOW IT SHOOTS MORE WATER FROM THE FANS all over the floor! I'm pretty sure i screwed up here and need to go back fix my metal bending magic trick, and clean the pan well. Tell me what you guys think. Thanks.
    "When people fear you, it means they have no respect for you—it’s just the fear that they feel. So if it comes down to it, I’d rather be loved. Love and respect go a lot farther than fear." Frank Zito
    Jul 2006
    74
    865
    26
    Re: Imeco evaporator
    If you mean the piece of sheet metal that covers the drain opening, it needs to be there. Without it the water comes back out of the drain and goes back up to the fans.
    Jun 2009
    United States
    45
    34
    yep. thats the one. thanks for the answer.
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. How can I reduce evaporator pressure?
    By mansari in forum Fundamentals
    Last Post: 05-09-2009, 01:59 AM
  3. EVAPORATOR leaked
    By James priyono in forum Air Conditioning
    Last Post: 23-05-2009, 10:19 AM
  4. Absortpion Refrigeration - Evaporator Basics
    By knudo in forum Fundamentals
    Last Post: 28-08-2007, 08:03 AM
  5. What is the best location for a evaporator fan?
    By Jasno999 in forum Fundamentals
    Last Post: 21-02-2007, 12:34 AM
