    elmdas's Avatar
    elmdas Guest
    Question BP spill & Mini-split demand/market
    Hello All,
    There are a lot of residences in the northeast using hydronic heat, so given the BP disaster and ongoing oil situation, why shouldn't these folks be a prime market for mini-splits? I'm thinking about getting back into installing these systems. Folks are getting old, need air conditioning, they have no ductwork currently, and need a localized backup heat source.
    Anyway, I've not done refrigeration work since the mid 90's using R22, and I need to upgrade my stuff, so I'm thinking about a YellowJacket 69080 vac gauge, and a yellowjacket BruteII model 46013 to replace/upgrade my gauges. Would anyone care to comment on if the 4 hose manifold is worth the extra money, or if it's actually that practical to use? I'm thinking about using that 4th hose just for the vacuum pump and gauge, but will the line collapse? I used to use a copper vacuum line, but mabye there's a new better way.
    Also, I'm wondering what I'm getting into with the mini-splits, do they have proper schraeder valved service ports already installed, or does the installer have to braze them in? At least my torch still works.
    Thanks,
    John B.
    11,025
    Re: BP spill & Mini-split demand/market
    3/8" vac hoses do not collapse.
    Splits have access ports pre-fitted.
    New gases, R410a, run at higher pressures than you are used to, get gauges/manifolds suitable.
    Upgrade your nitrogen gauge, test pressures could be up to 40 bar, 580psig.
    Torque spanners required for flare nuts.
    Apr 2008
    Southampton, England
    49
    1,023
    36
    I'd say the 4 port gauge is worth the extra spondolicks.
    Had to hand mine back when changing company and noticed the 4 port easier to use with less hose swapping.
    Don't forget when vaccing out you can connect the yellow line to the bottle and vac that out as well to save purging the line.
    Splits over here are pre-charged and have a schrader built on to the suction service valve - kind of like a rotalock. Bigger units have one on the liquid valve also. Most will have a schrader on the discharge inside the unit as well, but don't count on it. Wanted to check one today (on a Sanyo) and there wasn't one!
    helenk579's Avatar
    helenk579 Guest
    Quote Originally Posted by elmdas View Post
    Hello All,
    Thanks,
    John B.
    I also think so.
    n.ireland
    45
    38
    think your a wee bit out with the nitrogen gauge,mitsi electric recommend doin a strength test to 600psi for 20 mins..correct me if i,m wrong
    11,025
    Quote Originally Posted by aircool View Post
    Aw, what's 20psi between friends?
  1. Servicing a LG Mini Split 410a
    By wrangoth in forum Trouble Shooting
    Last Post: 28-04-2010, 06:59 PM
  2. Mini split system heating, but not cooling well.
    By tirider in forum Heat Pumps
    Last Post: 06-11-2009, 09:17 PM
  3. Amcor mini split control board
    By alive2live in forum Air Conditioning
    Last Post: 25-10-2009, 01:06 AM
  4. Need help trouble shooting mini split ac error code "e4"
    By grindrx in forum Air Conditioning
    Last Post: 23-07-2009, 08:57 PM
  5. Klimaire mini split installation
    By JohnK in forum Air Conditioning
    Last Post: 19-05-2009, 07:51 PM
Tags for this Thread
