Results 1 to 35 of 35
    Jan 2007
    Poland
    49
    12
    Compressor above condenser.
    Dear all, placing condenser with liquid receiver below compressor (~5 meters below) cause that installation does not function? Could you give me theoretical background concernig that issue please?
    Pawel
    11,025
    Re: Compressor above condenser.
    What does not function in your set up?
    Oct 2005
    IRAN
    878
    Hi there,
    Most probably you have a problem with liquid line which goes up 5m. You have to calculate the correct liquid line size and also required sub cooling so that a solid liquid line reaches the TEV.
    Even Einstein Asked Questions
    Jan 2007
    Poland
    49
    12
    Thx for expl.
    Brg Pawe.
    Oct 2003
    5,630
    34
    Quote Originally Posted by Pawel_Wisnik View Post
    Pawel
    I don't see any problem with this setup.
    But what IS your problem exactly?
    May 2008
    66
    802
    probably a low pressure problem on the LP inlet of the compressor..... i think?
    Ice
    Jan 2007
    Poland
    49
    12
    Hi Peter,
    I am forced to apply such layout in one of my sites within a couple a weeks to come, but in the meantime I heard an opinion that such setup did not work at all (but without explanation why it did not and what was the main problem), in my opinion there is no threats in it, but just to be sure I also dropped post here to see opinion from you, opinions that I appreciate very much .
    Pawel
    Dec 2002
    South Africa
    83
    41
    Possible accumulation of oil in receiver?
    Oct 2003
    5,630
    34
    Make sure your line going up is large enough in diameter and if you want to use EEV's on your evaporators, try to install a subcooler (PHE) after your receiver.
    Nov 2009
    Minsk, Belarus
    171
    15
    Hi Peter,
    Pawel
    May be it was a case when compressor above condencer and receiver near the compressor (above condencer)?
    In some places will have to think ...
    May 2008
    66
    802
    i am more thinking in the line of the compressor. problems whit the oil return. i don't think there was a refrig mensioned in this topic.
    Ice
    Apr 2005
    INDIA
    63
    84
    It should work, If it is not working give the pressure reading of LP and HP?
    RGDs
    Jan 2009
    Australia
    108
    Provided the line size is right, it should work ok. Oil return can be a problem in condensers lower than the compressor particularly if the ambient conditions are low and head pressure control is poor. It often turns turns to sludge and sits in it occupying condenser area. Then a young tech comes along - sees no oil in the compressor and promptly adds another litre or two which also ends up in the condenser and so on it goes.
    Best plan is to probably think about an oil separator to take care of the oil issues, make sure the lquid line has a low enough pressure drop and it should work fine.
    Jan 2007
    Poland
    49
    12
    Hi Peter,
    I do so
    Pawel
    Jan 2007
    Poland
    49
    12
    Quote Originally Posted by icecube51 View Post
    Ice
    in my opnion there should not be a problem with oil, it flows freely down to condeser via discharge line then within condenser and liquid receiver dissolves in refrigerant.
    Oct 2003
    5,630
    34
    Indeed, you will not face oil problems and surely not in the discharge and liquid lines. Liquid will fush out all the oil
    Nov 2009
    Minsk, Belarus
    171
    15
    In my opinion there is one problem of your system.
    On summer ambient temperature may be high then room temperature where compressor situated. If compressor stop long time then its temperature may be smaller then condencer (and receiver). And refrigerant may migrate from receiver through condencer to head of compressor and condense there. When compressor start then may be hydraulic shock...
    May 2008
    66
    802
    always safe to mount an oiltrap evry 3mtr.
    Ice
  19. #19
    Oct 2003
    5,630
    34
    In upgoing liquid lines and flowing down discharge lines?
  20. #20
    Apr 2008
    215
    A non-return valve in the liquid line outlet from the condenser would not be a bad idea...
  21. #21
    May 2008
    66
    802
    in this case Peter, upgoing.
    Ice
  22. #22
    Split Croatia
    57
    6,151
    36
  23. #23
    Jan 2007
    Poland
    49
    12
    Quote Originally Posted by Aik View Post
    in this case machniery room always is at equal or a bit higher temperature than ambient, even in summer time.
  24. #24
    Oct 2003
    5,630
    34
    An NRV will give you an additional DP in your liquid line and decrease overall system performance.
    Why you need it anyhow? What is its benefit?
  25. #25
    Nov 2009
    Minsk, Belarus
    171
    15
    When compressor stop, if temperature of condencer and receiver will bigger than compressor, than refrigerant in liquid phase will evaporate in condencer and condence near more cold compressor (migrate).
    Then I don't see problems in your system...
  26. #26
    Nov 2009
    Minsk, Belarus
    171
    15
    Quote Originally Posted by Gingerair View Post
    In this system it would be better install check valve in the gas line on inlet to the condencer.
    Oiltraps don't stop migration...
  27. #27
    May 2008
    66
    802
    but whit the migration of the refrig, some oil will return, so the compressor will always have some oil to work whit.
    Ice
  28. #28
    Split Croatia
    57
    6,151
    36
    I don't see any problem except that subcooling must be enough to compensate for 0,63 bar pressure drop due to liquid column of liquid refrigerant in 5 m pipe.
    Oil is not of any concern if it is soluble with liquid refrigerant.
  29. #29
    Nov 2009
    Minsk, Belarus
    171
    15
    Ice
    In any case in Pawel_Wisnik's system oil trapes don't need on discharge line.
    I have the same opinion...
  30. #30
    Oct 2003
    5,630
    34
    In the Suva example, gas line, 33.9 psi at bottom and 34.1 psi at the top
  31. #31
    Split Croatia
    57
    6,151
    36
    Deleted!
    You are right, it is mistake.
  32. #32
    Oct 2003
    5,630
    34
    Why then the bottom weights less?
  33. #33
    Split Croatia
    57
    6,151
    36
    I think you misunderstand my last post. Deleted is my comment (which is wrong) that everything is OK on that Suva picture, because i did not paying attention at what is bottom and what is up.
    Than I confirmed that you are right.
  34. #34
    Jun 2010
    United Kingdom
    48
    This is Gareth Jones
    Regards,
    Gareth
    CNM ONLINE
  35. #35
    Jun 2010
    United Kingdom
    48
    Regards,
    Gareth
    CNM ONLINE
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. Replies: 2
    Last Post: 08-06-2010, 11:12 PM
  3. How to measure COP (evaporative condenser)
    By Juho in forum Technical Discussions
    Last Post: 04-06-2010, 07:08 PM
  4. Evaporative Condenser system COP
    By Juho in forum Commercial
    Last Post: 03-06-2010, 09:23 AM
  5. Air Cooled Condenser Leakage Problem with R-404A
    By RADHAKRISHNARAO in forum Technical Discussions
    Last Post: 30-07-2008, 12:21 PM
