    Nov 2009
    Minsk, Belarus
    171
    15
    Protect solenoid from hammer
    Danfoss recommend: protect solenoid from hammer when it closing is to use T-shaped pipe before solenoid.
    What do think about this?
    Do you use it?
    How does calculate the dimentions of T-shaped pipe?
    There are many questions, I offer to discuss theirs...
    In some places will have to think ...
    Oct 2006
    1,843
    21
    Re: Protect solenoid from hammer
    Quote Originally Posted by Aik View Post
    Do you use it?
    I think it is a great idea and for years I worked on cases with this set up inside and did not know.
    I always though it was the branch line for hot gas defrost to be fitted if required and it was only a
    few years ago on this site that I was informed as to the true nature of the Tee fitting.
    I have seen my fair share of TEV failures due to liquid hammer and had I know about this simple
    solution, I would have fitted them 25 years ago
    So I think the idea of an expansion chamber to minimise the damage from liquid hammer is great.
    All the best
    taz
    Nov 2009
    Minsk, Belarus
    171
    15
    I think so, but there are some questions such as what distance between solenoid and T-shaped pipe must be? What the lenth of thise pipe?
    I hear that the lenth of T-shaped pipe is near 3 - 5 of diameter of liquid pipe, but I don't see it in any literature source.
    And also think that it would be great to install T- shaped pipe before impact electronik expansion valve...
    So is any other information about thise piece of pipe?
  1. Replies: 16
    Last Post: 16-06-2010, 05:43 PM
  2. Solenoid valve diagnostics
    By Dougiefresh63 in forum Trouble Shooting
    Last Post: 08-03-2009, 10:39 PM
  3. Liquid solenoid valve mystery
    By mohamed khamis in forum Electrical
    Last Post: 04-08-2008, 08:59 PM
  4. Luiquid line vibration and liquid hammer
    By Infinity in forum Trouble Shooting
    Last Post: 09-02-2007, 10:22 PM
  5. Blistering Hot Gas Solenoid Diaphragm Issue
    By dewars_aus in forum Trouble Shooting
    Last Post: 18-07-2006, 09:37 PM
