Page 2 of 5 FirstFirst 12345 LastLast
Results 51 to 100 of 220
  1. #51
    Jul 2002
    Washington
    67
    22
    Originally posted by Dan
    Interesting pictures, Aenigma. 45% silver with paste flux is what I would use. Some would use Stay-brite, but I much prefer 45% silver.
    Ah thanks
    I dont need to solder any steel lines for my cascade chiller anymore.
    I picked up an 8K a/c unit and used that compressor for the cascade chiller.
    So I am getting close....
    Got the beast off the table and on the floor too,so now I can get the box screwed on and everything.
  2. #52
    May 2002
    Edmonton, AB Canada
    38
    Aenigma - sounds like you are a lot closer to the knowledge level of the AC guys than am I. I soldered up my evaporator the other day....but was somewhat balked by the tips of the compressor...heating them I can't get them off so I don't think it's solder, but they are considerably larger than the 1/4" tubing...which actually appears to go inside the silver tip on the end of the evaporator.
    I guess I'm going to have to try truck this whole rig down to an AC shop, and see if anyone is willing to touch it.
    One more question....there originally was a thermostat on this system, as the compressor and condensor are from a wine cellar cooling unit. Since I need the system to run 100% duty cycle, I have removed that thermostat. Will the compressor continue to run, as long as power is applied to it - or is it somehow going to continue to expect regulation?
  3. #53
    Jul 2002
    Washington
    67
    22
    Yep it will run fine without the thermostat.
    I am not quite clear on what you are trying to unsolder?Are you using an oxy/acetylene torch?
  4. #54
    May 2002
    Edmonton, AB Canada
    38
    Nothing that fancy...just using a propane burner...it's plenty to melt silver solder...but I didn't want to apply heat to the tip of the compressor for too long. It does sand off very shiny silver...but it isn't silver. I suppose it could be another bonding material..
  5. #55
    Jul 2002
    Washington
    67
    22
    Probably copper/silver.
    I use silflo copper brazing rods.
    They melt at about 1400f thats why your not getting thos off with a propane torch
    Also if it is copper soldered to steel,which i am sure it is.
    Then it is probably some other kind of solder that melts at really high temps.
  6. #56
    May 2002
    Edmonton, AB Canada
    38
    Obviously if it took higher heat to get it on there.....the compressor won't be damaged by the higher heat required to remove it? Other than welders, I don't know anybody with a better torch.....which is why I probably have to involve an AC shop fairly soon. I also don't have a vacuum pump to charge the system...
  7. #57
    Apr 2001
    79
    5,071
    35
    Copper to steel requires silver solder. Propane probably won't do the job. A TurboTorch using MAPP gas might do it for these small systems, or an Oxy/Acetylene set will be needed.
  8. #58
    Jul 2002
    Washington
    67
    22
    So you having any luck with that compressor Hubris?
  9. #59
    May 2002
    Edmonton, AB Canada
    38
    Unfortunately I haven't had time to take it to a shop. I don't have the equipment or expertise to solder the pipes, evacuate the system, and charge with refrigerant.
    The local AC shops seem to be pretty much only open during business hours....which is a little hard to accomodate, since my dayjob is keeping me more than busy at present.
    Sigh...it's still exactly as it was, when last I posted. Evaporator is soldered together.....but the wet line and suction lines need to be soldered.....plus I still have no idea how much capillary tubing I'll need to use for this setup.
    I need an expert...and I haven't yet found one locally who is willing to help - even for money.
  10. #60
    Jul 2002
    Washington
    67
    22
    Well it isnt hard at all to do.As long as you have guages and a vaccum pump your set.Oh and a torch that gets hot would be nice.
    Go ahead and icq me at 23619435....
  11. #61
    Jun 2002
    Portugal
    42
    here's my cooling unid for my PC (CPU)
    WEb cam sucks
  12. #62
    Jun 2002
    Portugal
    42
  13. #63
    Jun 2002
    Portugal
    42
    this unid is a r409a and it gets to -50c / -51c ... if I let it runing idle for about 45mim...
    It get -40c in 5mim, -45cin 10mim... and -49cin 30mim :P
    BUT...
    W any load at all... it wont cool!
    Like... If I put the evapo. in 1/2L of 30c water... the evavpo gets 29c...at it only start to drop to 28c in 3 mim or soo...
    It needs more refrigeranT?
  14. #64
    Jun 2002
    Portugal
    42
    Could be this tube... that is too small...?
    Cos it have the capilar tube in it.. and can be a botneck ?
  15. #65
    Jun 2002
    Portugal
    42
    ... what do u guys think...?
  16. #66
    Apr 2001
    79
    5,071
    35
    For a proper evaluation, the evaporator needs to be attached to the CPU under normal load. Then after it runs for awhile, we need the following information:
    Type of refrigerant
    Low side pressure
    Suction line temperature near the evaporator
    Suction line temperature near the compressor
    High side pressure
    Condenser air in temperature
    Condenser air out temperature
    Liquid line temperature near the condenser
    Liquid line temperature near the cap tube
  17. #67
    Jun 2002
    Portugal
    42
    DAMN!
    Hmm... Was a A/C guy that put the R409a in it... I dont know how to mesure the presure
  18. #68
    May 2002
    Edmonton, AB Canada
    38
    Depending on how your friend built your system, he may or may not have installed access points where pressure can be read, using the proper type of guage. It shouldn't be too tough to get temperature readings for the various locations though.
  19. #69
    Jun 2002
    Portugal
    42
    I can give some temps tho...
    Type of refrigerant --> R409a
    Low side pressure --> ??
    Suction line temperature near the evaporator --> w load ( a 1/4 L of 35.c water ) it gets about 24 in 3mim The water is now 27c
    Suction line temperature near the compressor --> 30 mm (3cm) from the compressor 21.6c 60mm (6cm) from the compressor.. 18.3c
    High side pressure
    Condenser air in temperature -->21.5c
    Condenser air out temperature -->22.2c
    Liquid line temperature near the condenser--> line that goes to cond. at 2 cm from it.... 33.6c
    Liquid line temperature near the cap tube --> 1 cm from the deshumifider (i think is deshumifuder) 24.2c
    That's it... any more to mesurE?
  20. #70
    Apr 2001
    79
    5,071
    35
    The water is not the proper load. Let's try getting the same measurements with no load. Wait until it gets as cold as possible before taking the measurements.
  21. #71
    Jul 2002
    washington
    77
    22
    water could be a good load, if your accurate. it takes 1 caloire to heat/cool 1 liter of water 1 degree. you will need to convert BTU's to calories.
    one mans trash is another mans treasure
  22. #72
    Aug 2001
    Leominster, MA
    71
    Cool necessity is the mother of invention
    As Gary said, most computera are rated for room temperatures, why in the hell do you want to cool the computer? Cool the space, and then you eliminate the expence and possibility of condensation or moisture getting on the board. Then use an internal power fan.
    Years ago My brother was doing computer rooms and they sent chilled water thru the internals of the units. The computers alone, took up about 2000 square feet of space. They were cogeneration with 4 back up ups's. All that equipment is gone now, along with 80% of the computer equipment and the cooling requirements. All PC's now....and PKG RTU's.
    Things have changed..alot of money lost on computer rooms since the internet and the WWW came into the equation.
    My wife says I don't listen to her....or something like that....
  23. #73
    May 2002
    Edmonton, AB Canada
    38
    The amount of resources required, plus the facilities available to us - are what prevent us from cooling our entire rooms to temps where processors can be kept at or below freezing temps.
    Cooling water that is used to cool the cpu.....is fairly efficient. Having the evaporator directly contact the CPU...is fairly efficient. Even Gary's idea of mounting the guts of a computer inside a tiny commercial freezer - is fairly efficient. Cooling an entire room such that a standard heatsink, or other conventional means can keep the CPU in the intended range - is not practical. Remember, this is being done in a residence....it is not generating money - there is no value in having a room too cold to sit in, and costing $20/day in power to chill.
  24. #74
    Jul 2002
    Washington
    67
    22
    Re: necessity is the mother of invention
    Ever heard of overclocking?Guess not.
    Computers arent rated for certain temperatures,the colder they are,the faster they run(to a certain point).
  25. #75
    Jun 2002
    Portugal
    42
    DAMn... I dont know why... but this is taking way to long to get to -40c!
    It usto to be like 5 mim to get ot -40c now it is runing for 20 mim and is at -24c but still lowering..
    WTF is rong w this unid?!
  26. #76
    Jun 2002
    Portugal
    42
    Most of the times when I turn on the compressor runs cold... only after 30 mim it get hot.. and the line that goes to the condensator... normaly goes hot in the 1º 5mim... then.. it gets normal.. and after some time it gets REAL hot!
    Is this all normal??
    Is it normal... after shutting down the Compressor... it gets REAL HOT.... Like 60c or soo...
    All this w out load.
  27. #77
    Apr 2001
    79
    5,071
    35
    We can't see it from here. All we can see is the description and the temperature measurements. Saying "hot" requires us to guess what you mean.
  28. #78
    Jun 2002
    Portugal
    42
    Well.. when I say REAL HOT.. its like 55c or soo....
    When I say HOT its more like 35c/50c +
    Normal is around the ambient temp. NOw is 25c
  29. #79
    Apr 2001
    79
    5,071
    35
    My computer isn't doing what I think it should do. The top of the monitor is sorta warm. The screen has fingerprints on it. It doesn't make any noise when I shut it off. And my scanner isn't hooked up. WTF is wrong with my computer.
    I gave you a list of temperature measurements earlier. These are the measurements that tell us what the system is doing.
  30. #80
    Jun 2002
    Portugal
    42
    DAMN [CEnSUrED] Fu*Ing POS!
    This [Censured] dont go lower than -29c now!! AGHRRRR|!
    Well... the temps in the condensator are THE SAME w or W OUT LOAD! about 33c in the line that goes to the condensator and 24c that comes out...
    The evapo w the load (120w TEC.. I put it when the evapo gets to -29c) gets from -29c to 56c in less than 3 mim|! and takes about 4.30mim to get from 56c to 0c w the Tec off...
    The return line gets about 17c near the compressor....
    and about 53c near the evapo. <--- w LOAD
    SOMEBODY HELP ME!!
  31. #81
    May 2002
    Edmonton, AB Canada
    38
    Are you saying that the evaporator is 53C under load, or that the return line coming out of the evaporator is 53C under load? If the temps are 53C coming out of the evaporator, and then drop to 17C before they reach the compressor....there is definately a problem.
    I'm sure the experts would correct me....but if the 120W load is that drastically overheating the evaporator - but that the phase change is still dropping refrigerant temps as it moves back towards the compressor....
    Either the phase change is happening too late....or there isn't enough refrigerant in the system to deal with the load of 120W.
    (here's my first diagnosis....based on very little knowledge. Help me learn folks....was I even close?)
  32. #82
    Apr 2001
    79
    5,071
    35
    Sorry, but that's not a diagnosis. That's a wild guess based upon a questionable interpretation of an incoherent statement. Aside from that, it wasn't too bad for a first effort.
  33. #83
    Jul 2002
    washington
    77
    22
    a BTU can cool 450mL (aboutone pound of water)
    of water by 1 degree in one minute. My 8500 BTU airconditioner can cool 102 gallons of water by 10 degrees (celcius) in one minute.
    thats one way you could check and see if your AC unit is working somewhat to its full potential.
  34. #84
    Jul 2002
    washington
    77
    22
    Originally posted by Robearbam
    Wow! Just what is it we are trying to cool down? An A/C system in a computer case? I thought the multi hole cut case with several 4" fans was a little overkill. A great site for PC cooling and over clocking is "maximumpc.com". I do believe they have a design for a heat pipe that cools the proc no matter what the freq is. Additional case cooling is supplied with fans which should be more then whats needed for today's super chips. I would personally keep any running motors far from the PC except the 12VDC fans. Were haven't reached micro wave freqs on the proc yet...I think then we will have to do something about further cooling down the PC.
    ive heard and seen of a Macintosh plus that ran at 2ghz and used liquid nitrogen to cool it and the floppy drive.
    and you thought multi hole cut cases were overkill? my gateway 2000 P-166mmx has some high CFM 6" brushless 120v fans getting air to circulate over the flaming hot videocard, roasting ethernet adaptor, and my toasty SB16/AWE32 soundcard. i also have a 55w peltier cooler on my PCI chipset.
  35. #85
    Jun 2002
    Portugal
    42
    once again I ask...
    Could be this tube a bit of the suction tube (5mm) that have inside the capilar tube (3mm) that is causing all this bad performance...!?
    http://www.refrigeration-engineer.co...s=&postid=5515
  36. #86
    Jun 2002
    Portugal
    42
    This is w out load... after 2h runing :P
    W the evapo at -40c
    Suction line temperature near the evaporator --> -21c 1CM (10mm) from the Evaporator.
    Suction line temperature near the compressor --> 20 mm (2cm) from the compressor 29.6c 60mm (6cm) from the compressor.. 19.6c
    High side pressure ??
    Condenser air in temperature -->25.3c
    Condenser air out temperature -->25.3c
    Liquid line temperature near the condenser--> line that goes to cond. at 2 cm from it.... 40.1c
    Line that comes out of the condensator--> 24.2c
    Liquid line temperature near the cap tube --> 1 cm from the deshumifider (i think is deshumifuder) 27.2c
    This time was mesure twice
  37. #87
    St. Louis, MO
    509
    a BTU can cool 450mL (aboutone pound of water) of water by 1 degree in one minute.
    Your mixing energy units (Btu's) and power units (Btu/min). A Btu will cool one pound of water one degree Fahrenheit. A Btu/min will cool one pound of water one degree Fahrenheit in one minute...
    Mmmm... an overachieving a/c unit 102 gal * 8.33 lb/gal * 10°C * 1.8°F/°C = 15,294 Btu. If cooled in one minute: 15,294 Btu/min = 76.5 tons...
    Prof Sporlan
  38. #88
    Jun 2002
    Portugal
    42
  39. #89
    Apr 2001
    79
    5,071
    35
    This system doesn't have nearly enough R409A in it. It is almost empty.
  40. #90
    Jun 2002
    Portugal
    42
    OK... Now I have to refill it
    It must have some leak in the evapo
  41. #91
    5,667
    How can you have a 16deg C differential across the discharge entering the condenser and the liquid leaving the condenser with no increase in air temperature entering and leaving?
    Where is the heat energy going?
  42. #92
    Jun 2002
    Portugal
    42
    I asked that question myself
    BUT... I think that's because is a BIG radiator.. (+/-) :P and it have a BIG FAN in it!
    The radiator is 29X25cm...
  43. #93
    Apr 2001
    79
    5,071
    35
    There isn't enough heat energy to measure the difference in delta-T.
  44. #94
    Jul 2002
    Washington
    67
    22
    Oh sure you dont listen to me when I tell you its undercharged
    you need to charge it with a load on the evap,like a pelt would be good.
  45. #95
    Jul 2002
    Washington
    67
    22
    Because it is undercharged.Not enough pressure to get warm,just the discharge will be warm.
  46. #96
    Jun 2002
    Portugal
    42
    We been chating and I already said that I needed... long before gary mention it... I was looking for confirmation...
  47. #97
    Jul 2002
    Washington
    67
    22
    Well I got my system going finally.
    Problem after problem heh
    First was this:
    From it being banged around from being moved up 2 stories a cap wire came loose and i didnt notice...so the compressor wasnt working and was acting as an evap
    So then after getting it going I left it running overnight full load using SETI.TBird 1.4@1731 as of now
    But I dont know cpu temps because the socket temp probe doesnt work too great in these conditions
    So anyways the pump quit while I was sleeping so I woke up to a Halt screen,but I guess the mineral oil saved the cpu.Im not using methanol anymore.Too toxic and sucks when your trying to prime your pump and you get a mouth full of it.
    so anyways the mineral oil gets really warm so I need to make a heat exchanger for it,thinking of just phase change cooling it.
    Gotta insulate the res and some other things also.
    got some work to do....
  48. #98
    May 2002
    Edmonton, AB Canada
    38
    You're crazy man....
    One phase-change system to cool the evaporator of another system that actually cools the cpu. Then another phase-change system to cool the oil sitting around your motherboard....
    Sigh...all I want to get going is a single system to cool my cpu in a normal case...
  49. #99
    Jul 2002
    Washington
    67
    22
    Naw nothing is cooling the oil
    I need to make a heat exchanger though....
  50. #100
    Jul 2002
    washington
    77
    22
    Generally speaking a powerful processor is going to be making something like 100W of heat, the various other components on the motherboard perhaps another 30W, the video card making perhaps 40W of heat......what exactly would it take to keep a chamber of dimensions like I listed....below freezing? While there are some who really desire extremely low temps, there are decreasing gains in performance as temps decrease. Most decent heatsinks can keep a cpu within 10-15C of ambiant temps....if it's all stored in a freezer at -10C, that should yield pretty good results.
    Can I buy that in a pre-made solution...and for a reasonable price?
    ive checked, and a pentium III can only make out 20-35W of heat at the VERY extreme end. its not much more for a P4.
    my Gainward mobo makes only about 5W of heat, but i belive i could cook a meal for an army on my 16mb videocard.
  1. Daikin fault codes
  2. System Burn Out Troubleshooting
  3. Replies: 19
    Last Post: 15-04-2008, 07:03 PM
  4. What is System balance?
    By shogun7 in forum Technical Speculations
    Last Post: 19-01-2006, 09:47 AM
  5. Refrigeration system proposal; comments please.
    Last Post: 01-01-2003, 03:42 PM
