14-06-2010, 09:12 PM #1
can you add extra lines in my beer cooler
i've got a maxi 310 beer cooler, but only has 2 product line pipes installed. But the machine has holes and instruction on the front for 4 products.
How can you intsall the pipes to run more products through the cooler?
14-06-2010, 11:34 PM #2
Re: can you add extra lines in my beer cooler
I would ask the manufacturer, check with Google.
22-10-2010, 06:57 PM #3
The Maxi 310 comes in a single, twin, 3 way and 4 way coil config. It is actually very easy to swap out the coils. We have 4 way coils in stock, just keep in mind that the more product coils you use the more the cooler has to work to keep everything at temp. The cut out on these are set to -2. It takes approx 3.5 hours for a full ice bank to build with no load.
Beer cooler : have I charged it correctly?
By acnerd in forum Trouble ShootingReplies: 62Last Post: 16-08-2009, 01:10 PM -
R404A Beer Cooler
By NwBurbs in forum Trouble ShootingReplies: 5Last Post: 13-05-2009, 06:40 PM -
If Operating Systems Were Beers
By nike123 in forum Chit Chat & Service StoriesReplies: 1Last Post: 28-04-2008, 10:53 PM -
Saline solution in beer cooler
By Rabmax in forum Technical SpeculationsReplies: 2Last Post: 06-06-2007, 06:58 PM -
Cervitor Kitchens Beer Keg Cooler
By doogdoog in forum FundamentalsReplies: 5Last Post: 16-10-2006, 09:48 PM
