14-06-2010, 11:29 AM #1
Shell and tube Heat exchanger Design
Hi!!! everyone
I wanted to understand how complete designing of a shell and tube heat exchanger U-bundle type is done.
I want to know what are the thermal as well as mechanical design calculations required for the designing of U-type S & T Heat exchanger
Any help (explanation, text, references etc,) will be grateful.
Thanks in advance
15-06-2010, 11:47 PM #2
Re: Shell and tube Heat exchanger Design
You want an awful lot of things, I would suggest that you attend college or beginning reading refrigeration design text books.
edit: I see that you are a student, perhaps you should start research on your subject matter.Brian - Newton Abbot, Devon, UK
25-06-2010, 12:02 PM #3
thanks for ur suggestion
Fabrication of Cooler Tube & Shell Cooler
By rickyccong in forum Technical DiscussionsReplies: 1Last Post: 27-07-2009, 02:25 PM -
Water velocity in Shell and tube HE
By wilsoncheung in forum IndustrialReplies: 15Last Post: 07-04-2009, 07:59 PM -
ERBAY shell and tube heat exchanger
By chemi-cool in forum Air ConditioningReplies: 3Last Post: 04-06-2008, 05:15 AM -
Vahterus Heat Exchanger
By samiam in forum New TechnologiesReplies: 4Last Post: 19-04-2008, 10:33 AM -
R134a / Water Heat Exchanger Sizing
By ACEprod in forum CPU OverclockersReplies: 0Last Post: 31-03-2008, 07:34 AM
