Results 1 to 11 of 11
13-06-2010, 11:46 AM #1
Mitsi Electric PUHZ RP10 KVA Compressor will not run
This unit has been insalled about a week and was running great, but got a call to go and check the unit this eve (outdoor model PUHZ RP10KVA) about the unit not cooling.
Turned the unit on and the fans run outside for about 2 secs then off and repeats this about 5 times.
The outdoor unit is flashing fault code 3 green and 4 red .
I took the 3 wires off compressor and checked windings, 2 are 1.0 ohms and the other is 0.9.
When power is turned on with these wires disconnected thetre is 23.4v between 2 phases DC and the same fault code appears with the wires disconnected.
I have checked compressor wires where they go onto board and all seems fine.
Has anyone had this problem ?
Chris
14-06-2010, 10:42 AM #2
Re: Mitsi Electric PUHZ RP10 KVA Compressor will not run
Faulty power board
14-06-2010, 06:11 PM #3
hi chris
i recently ran up a mitsi system and had a problem where the compressor was making a noise and failing to start
had error lights cant remember what these were now.
turned out to be a faulty power board.
cheers lee
14-06-2010, 09:55 PM #4
Hi lee
The compressor on this unit was doing nothing at all, the fans were the only thing that would run.
only the red wire was live to comp the other 2 nothing.
Its the first time this has happend to me normally mitsi are very reliable.
Chris
14-06-2010, 10:23 PM #5
14-06-2010, 11:24 PM #6
My new part will be here in the morning thankfully
Which should save a little ear bashing from the customer
15-06-2010, 05:05 PM #7
good luck let us know that it was defo the power board
cheers lee
15-06-2010, 08:32 PM #8
Hi lee
I got the new board this afternnon and replaced it this evening.
I am pleased to say everything is working fine now ,
What part of manchester are you from?
15-06-2010, 09:21 PM #9
hi chris glad to hear it. i am from urmston what about yourself?
just noticed northern ireland :-)
16-06-2010, 10:32 PM #10
Hi lee
My grandad used to live in flixton beside woodsend circle , I have a lot of family around that area as I was born there myself .
Hows the fridge trade over there at the min?
Chris
16-06-2010, 11:23 PM #11
hi chris yeah know it well lived here all my life.
its picking up at the company i work for, got quite a lot of work on so its very busy at the moment mate
Mitsi electric 10kw power inverter wall mount louver not available
By Chris2005 in forum Air ConditioningReplies: 4Last Post: 12-06-2010, 09:45 PM -
Mitsi electric fault codes?
By weidit in forum Air ConditioningReplies: 15Last Post: 22-12-2009, 10:54 PM -
Mitsi Electric RP6AA Pump Fault
By gwilliamson in forum Air ConditioningReplies: 8Last Post: 15-08-2008, 05:59 PM -
SR2 50 models electric SBY diagonostics made simple
By absolute-zero in forum TransportReplies: 5Last Post: 04-01-2008, 05:11 PM -
Mitsi electric large.
By Simon Butler in forum Air ConditioningReplies: 7Last Post: 29-10-2007, 10:04 PM
