    Sep 2009
    Idaho
    27
    Refrigerant loss from Hansen auto purger
    Hello all,
    I am faced with a current dilemma that you can help me answer. I work for a plant that has ~50k lbs nh3 charge. Four operating pressure systems, 7"hg, 24psig, 30psig, and condensing of 124-135 (design).
    We are currently purging from the condensing pressure, and the suction for our ap24 is at 24psig. The two highest of our four condensor receive 6 purge points each, at 15 min intervals. The two lowest receive 6 purge points ea at 5 min intervals. There is half inch purge line coming from each of the purge points into a common half in header. The total length of each purge line is about 250ft.
    Problem: I think I am losing a lot of refrigerant through the purger. Upon observation the bubbler appears to function fine, but short of watching it all day I could not confirm this. It has been suggested that the check valve is faulty, which I will check today. Hansen said that the unit is designed to use a 30# check valve. Sometimes the discharge end of the purger can get up to 32-37 psig for about 20min (from the normal 24psig).
    Thanks ahead of time.
    Nov 2004
    China
    176
    Re: Refrigerant loss from Hansen auto purger
    The purger would work much better if the suction was piped to your lower temperature suction (7"hg).
    Sep 2008
    Canada
    811
    Quote Originally Posted by simplygold View Post
    Hello all,
    Why do you think that you lose ammonia through the purger? Charlie N is right that purger will waste less ammonia at lower suction pressure.
    Jul 2005
    61
    68
    There should be three check valves, 1 PSID, 30 PSID and 200/225 PSID.
    The check valves are parts that Hansen included in the overhaul kit. So they a wear items. And I have sold a few over the years.
    The 1 PSID valve is on the line to the bubbler. Check to make sure it is a 1 PSID and not a 30 PSID. That would explain the high pressure reading. Or it could just be a wore out check valve.
    Aug 2010
    110
    14
    If it is an Auto purger then best to throw it away and fit a NEAP! I have recently done this and my purge problems have almost dissappeared.
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. which refrigerant ???????
    By bob007 in forum Trouble Shooting
    Last Post: 31-05-2010, 12:54 PM
  3. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
Tags for this Thread
