Thread: Fujitsu A0U24CL
09-06-2010, 02:45 AM #1
Fujitsu A0U24CL
Hi All,
Does anyone have an installation manual for the above titled unit? I am more interested in the electrical wiring of the indoor/outdoor units.
I am not getting power to the indoor/outdoor units at all. There are no lights, fans nothing. I wasn't the original installer however I do have my refer license and am familiar with other non-split units.
09-06-2010, 07:29 AM #2
Re: Fujitsu A0U24CL
Unfortunately, such model is not familiar to me. However ...
I hope that power supplies on unit are submitted
In a normal state all LED's outdoor PCB is OFF. LED's flashing if unit is in error mode. Check PCB outdoor. For this purpose is power supply OFF -> remove one thermistor or all thermistors from socket (CN11, CN12,CN13) -> power supply ON -> if LED's flashing is half good, if NO - PCB It is defective.
10-06-2010, 08:39 AM #3
Re: Fujitsu A0U24CL
Are you sure that is the correct model number??
I have access to wiring diagrams for ASU24CL / AOU24CL and that model is an inverter type machine. Looking at your picture the product looks more like a fixed speed compressor unit and by the looks of it much larger capacity than 24k BTU's say 30,0000 BTU or more if it has two condenser fans.
10-06-2010, 09:49 PM #4
Re: Fujitsu A0U24CL
10-06-2010, 10:19 PM #5
Re: Fujitsu A0U24CL
Good link, thanks.
The wiring diagrams for most split units are on the inside of the casing panels.Brian - Newton Abbot, Devon, UK
12-06-2010, 01:25 PM #6
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Fujitsu A0U24CL
There is AOU24D1, AOU24RLX, AOU24RLM, AOU24RLM1
It is not known to me AOU24CL.
Fujitsu AOY90TPAMF
By andy c in forum Heat PumpsReplies: 6Last Post: 08-02-2010, 04:22 PM -
your opinons on fujitsu please
By acgibo in forum Air ConditioningReplies: 18Last Post: 26-08-2009, 05:06 PM -
fujitsu wall mount volt free relay
By mike live in forum Air ConditioningReplies: 3Last Post: 09-04-2009, 08:26 PM -
Fujitsu PCB
By gwilliamson in forum Air ConditioningReplies: 6Last Post: 10-09-2008, 10:27 PM -
Fujitsu or not?
By LRAC in forum Air ConditioningReplies: 14Last Post: 29-08-2007, 09:45 AM
