Results 1 to 10 of 10
    gllitznz's Avatar
    gllitznz Guest
    Fujitsu AST18LSBCW error codes
    Hello there!
    We have a Fujitsu AST18LSBCW (indoor unit model no.) and recently, as it has been getting colder, we have come into the lounge to find it flashing what seems to be an error code (cuz it ain't heating!) The green timer light will flash continuously, while the red operation light will flash 5 times, pause, and then flash 5 times again, etc...I can't seem to find this error code anywhere?
    The only solution I have come up with is to turn the unit off outside, wait 10 minutes, then turn it on again and all is good, but it is a bit annoying to have to do that EVERY MORNING?!?!
    Any help as to what you think it might be would be greatly appreciated!
    Many thanks in advance!
    Cheers!
    11,025
    Re: Fujitsu AST18LSBCW error codes
    Not found your model but attached file has error codes which seem to be the same across Fujitsu.
    http://www.fgeurofred.co.uk/content/...%20Service.pdf
    Sep 2006
    New Zealand
    54
    Hi I have just checked fujitsu manual and I would advise you to call a fridge company to check. This could be 1 of 4 things and you will need a competent person to resolve this.sorry but soumds like it could be expensive.
    Cheers Andrew
    May 2010
    Russia
    168
    15
    gllitznz
    Download Service Instruction from http://rapidshare.com/files/39827913..._LSBC.pdf.html
    and see section Self-diagnosis function (p.51 and p.54 for AcrobatReader).
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by bigor_2 View Post
    gllitznz
    I don't see what is the point in giving openly service manual to end user with no qualification or tools to use it in order to resolve his problem.
    This error is in connection with inverter and compressor or outdoor fan current consumption, and even many of ordinary service engineers are not able to localize it or diagnose it without changing parts.
    So how that will help end user?
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by gllitznz View Post
    Cheers!
    I think that your error could be connected with power quality. Check with your power distributor that you have correct voltage witch doesn't drop out of acceptable limits when consumption is high (possibly at night with lot of electrical source heaters and other equipment is plugged in).
    But before doing anything, check your user manual and clean indoor unit filter.
    May 2010
    Russia
    168
    15
    gllitznz asked about the help.
    Any help is welcomed.
    gllitznz will choose.
    gllitznz's Avatar
    gllitznz Guest
    Many thanks for the advice, everyone...I will be in contact with a service person today and get back to you to let you know what they say!
    gllitznz's Avatar
    gllitznz Guest
    Just as a quick update...the air con tech guy came today and confirmed it was a "Compressor Location Error" (as per the service manual and he confirmed it with the Fujitsu folks)...so, he did some other checks and found the compressor to be faulty and is going to replace it...and THANK GOD it is still under parts and service warranty!
    Many thanks, all, for your help and advice!
    Cheers!
    11,025
    Thanks for the update , many do not bother , and we're glad that the problem is being resolved.
  1. Fujitsu AOY90TPAMF
    By andy c in forum Heat Pumps
    Last Post: 08-02-2010, 04:22 PM
  2. your opinons on fujitsu please
    By acgibo in forum Air Conditioning
    Last Post: 26-08-2009, 05:06 PM
  3. fujitsu wall mount volt free relay
    By mike live in forum Air Conditioning
    Last Post: 09-04-2009, 08:26 PM
  4. Fujitsu PCB
    By gwilliamson in forum Air Conditioning
    Last Post: 10-09-2008, 10:27 PM
  5. Fujitsu or not?
    By LRAC in forum Air Conditioning
    Last Post: 29-08-2007, 09:45 AM
