    Mar 2006
    Merate (LC) - Italy
    2,549
    Urgently looking for pressostatic 2 way valves for R410A
    I'm looking for 2-way pressure actuated water regulating valve, suitable for R410A (42 bar).
    Danfoss has got the VWR range, which is too small for my application. I'm looking for water side connections up to 2".
    Anyone any hint?
    Apr 2008
    215
    Re: Urgently looking for pressostatic 2 way valves for R410A
    What about these-
    http://www.georgfischer.co.uk/go/Pro...s/Type+130-135
    Johnson controls do a bellows type, but think it's only up 11/4 screwed 11/2 flanged-
    http://www.johnsoncontrols.com/publi...ants/v246.html
    Might be worth contacting Danfoss just to make sure they can't help you..
    Or you could always split the pipework & put more than 1 in...
    Aug 2009
    New Zealand
    2,554
    26
    May I offer acouple of alternatives.
    In the past when I required large valves, I installed a pressure transducer, PID controller and modulating valve. Seimens for example.
    Or (plant specific) have a perminent minimum flow and use a smaller valve to control remainer of flow via pressure.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Quote Originally Posted by Gingerair View Post
    It isn't pressostatic or self operated. It requires a piloting signal.
    It's not PS 42 bar.
    Been down that road. No happiness.
    Apr 2008
    215
    Hi No Nick Name
    The jc v264 has an Adjustable Operating Point from 13.8 Bar(200psi) to 27.6 Bar(400psi)
    The Maximum Refrigerant Sensing Element Pressure is 43.4 Bar(630psi)
    Page 4-
    http://cgproducts.johnsoncontrols.co...2476642713.pdf
    Or as Mad Fridge said, you could split the water pipework & just use 1 valve.
    Have seen systems before with the pipework split for 2 valves & the operating points staggered..
    Mar 2006
    Merate (LC) - Italy
    2,549
    thanks Gingerair. I'll look into it. I'm afraid it's not available in the EU, but I will call JCI to make sure.
    Apr 2008
    215
    Ok, let us know what you decide on..
  1. minisplit run with king valves closed - is it damaged?
    By cadillackid in forum Air Conditioning
    Last Post: 29-10-2009, 12:19 PM
  2. Too dependent on Danfoss Valves
    By kelvin_27_84 in forum Industrial
    Last Post: 24-01-2009, 08:33 PM
  3. Herl valves
    By BESC5240 in forum Industrial
    Last Post: 10-06-2008, 08:57 PM
  4. Hinari and how far to open valves
    By stryker in forum Air Conditioning
    Last Post: 14-04-2008, 01:47 AM
  5. dan foss tx valves
    By fuzzy in forum Trouble Shooting
    Last Post: 02-10-2007, 01:11 PM
