Thread: york
11-06-2010, 12:53 AM #1
york
4yr old york affinity quits cooling on hot days code 5 high discharge temp new condenser fan ,expansion valve help new thermostat
14-06-2010, 04:53 AM #2
Re: york
Hi this is probably due to high pressure ,check your charge and make sure u dont have noncondensibles in system.
THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
14-06-2010, 12:00 PM #3
Re: york
Hi, try cleaning your condenser coil with a LOW PRESSURE jet wash that has enough power to clean, but not damage the condenser fins. It may look ok from the outside but could be clogged internally.
You may have to strip the unit by taking any covers & fan blades off in order to get proper access. Just make sure any electrics are protected..
Let us know what you find..
York Chiller problems
By ingherrera in forum CommercialReplies: 18Last Post: 26-07-2011, 03:10 PM -
YORK ducted split
By ALONEI in forum Trouble ShootingReplies: 7Last Post: 10-07-2010, 02:18 AM -
York Screw Model YCASO330
By James K. Donell in forum Technical SpeculationsReplies: 1Last Post: 12-06-2010, 11:24 PM -
York ac model names
By Ebenezer in forum Air ConditioningReplies: 1Last Post: 21-10-2009, 08:09 PM -
York Recip NH3 Compressor Info
By CIR391 in forum Industrial CompressorsReplies: 1Last Post: 05-05-2009, 11:51 AM
