    Aug 2008
    44
    Bitzer HSKC oil change.
    Hi all,
    I have a question. I would like to know/learn how to do an oil change on a bitzer screw compressor. I have never done this procedure before especialy because the oil is on the high pressure/discharge side of the compressor.
    The pump down into the condenser doesn't work really well in this case I assume.
    Any tips would be really helpfull.
    Thanks.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Bitzer HSKC oil change.
    Yeah, pump down, close the valves, recover the refrigerant for as much as possible, drain the oil from the separator, change the oil filter, evacuate the compressor and while keeping the vacuum pump running, use the pressure difference for sucking the oil into the compressor separator.
    Aug 2008
    44
    Quote Originally Posted by NoNickName View Post
    Thank you for the quick answer
    I was expecting this kind of answer, but I wanted to know for sure because I don't want to take any risk loosing refrigerant because it's R407C.
  1. Bitzer s6f30 2-stage compressors
    By JONAH in forum Technical Discussions
    Last Post: 27-10-2010, 07:27 AM
  2. Bitzer CSH8561-125Y oil sight glass
    By Peter_1 in forum Industrial
    Last Post: 26-05-2010, 04:32 PM
  3. Basics or is it?
    By Fett in forum Fundamentals
    Last Post: 10-09-2009, 01:45 AM
  4. Rewiding Stator Bitzer Hskc 7461-80
    By nanev in forum Electrical
    Last Post: 01-09-2008, 07:32 PM
  5. nitrogen presure/ tempurature change.
    By neil74 in forum Fundamentals
    Last Post: 06-03-2008, 10:25 PM
