Thread: Fujitsu A0U24CL
    markkstrn's Avatar
    markkstrn Guest
    Fujitsu A0U24CL
    Hi All,
    Does anyone have an installation manual for the above titled unit? I am more interested in the electrical wiring of the indoor/outdoor units.
    I am not getting power to the indoor/outdoor units at all. There are no lights, fans nothing. I wasn't the original installer however I do have my refer license and am familiar with other non-split units.
    May 2010
    Russia
    168
    Re: Fujitsu A0U24CL
    Unfortunately, such model is not familiar to me. However ...
    I hope that power supplies on unit are submitted
    In a normal state all LED's outdoor PCB is OFF. LED's flashing if unit is in error mode. Check PCB outdoor. For this purpose is power supply OFF -> remove one thermistor or all thermistors from socket (CN11, CN12,CN13) -> power supply ON -> if LED's flashing is half good, if NO - PCB It is defective.
    Feb 2005
    Australia
    123
    Re: Fujitsu A0U24CL
    Are you sure that is the correct model number??
    I have access to wiring diagrams for ASU24CL / AOU24CL and that model is an inverter type machine. Looking at your picture the product looks more like a fixed speed compressor unit and by the looks of it much larger capacity than 24k BTU's say 30,0000 BTU or more if it has two condenser fans.
    May 2006
    Sussex
    362
    Re: Fujitsu A0U24CL
    Quote Originally Posted by markkstrn View Post
    Hi All,
    Try: http://www.fgeurofred.co.uk/default.asp?docId=12663
    Re: Fujitsu A0U24CL
    Good link, thanks.
    The wiring diagrams for most split units are on the inside of the casing panels.
    Split Croatia
    6,151
    Re: Fujitsu A0U24CL
    There is AOU24D1, AOU24RLX, AOU24RLM, AOU24RLM1
    It is not known to me AOU24CL.
  1. Fujitsu AOY90TPAMF
    By andy c in forum Heat Pumps
    Last Post: 08-02-2010, 04:22 PM
  2. your opinons on fujitsu please
    By acgibo in forum Air Conditioning
    Last Post: 26-08-2009, 05:06 PM
  3. fujitsu wall mount volt free relay
    By mike live in forum Air Conditioning
    Last Post: 09-04-2009, 08:26 PM
  4. Fujitsu PCB
    By gwilliamson in forum Air Conditioning
    Last Post: 10-09-2008, 10:27 PM
  5. Fujitsu or not?
    By LRAC in forum Air Conditioning
    Last Post: 29-08-2007, 09:45 AM
