Results 1 to 2 of 2
Thread: Evap valve
    Aragon's Avatar
    Aragon Guest
    Evap valve
    Guys, I'm pretty new in here...I have a system where there is a pilot operated solenoid valve fitted as a bypass between evaporator inlet and outlet..the pilot line is led from the expansion valve before the evap..any ideas why such a solenoid valve?? I feel that this bypass valve could result in liquid refrigerant coming to the compressor suction...whadya all ?/think
    Auckland
    74
    3,357
    37
    Re: Evap valve
    Sounds like an externally equalized expansion valve, if the pilot solenoid is 3 ported with a line back to liquid line, then it forces the TXV closed by putting liquid onto TXV to close it.
  1. TEV on long liquid line, liquid hammer
    By Peter_1 in forum Industrial
    Last Post: 21-02-2010, 09:37 AM
  2. LEV does not open
    By Yuri B. in forum Air Conditioning
    Last Post: 19-07-2009, 02:37 PM
  3. Replies: 2
    Last Post: 06-02-2009, 07:35 PM
  4. Compressor valve test
    By RackMechanic in forum Air Conditioning
    Last Post: 03-02-2008, 05:57 PM
  5. Benji
