Thread: UltraTroc Air Dryer Failure
Threaded View
15-04-2005, 05:47 PM #1
This thing is a little over a year old and failed. Compressor is locked up not shorted. I lost the potential relay first due to high current. One of the terminals fried. I replaced it and ran good for a few days. Now the compressor just hums and goes off on overload. My question is should I do a reverse purge on the cap tube once the system is open and before I replace the comp and filter? I have and do a lot of 12 chillers and never practiced this on these systems. They seem to run forever after a comp change. This is only about the 4th time I've dealt with a 134a system and wondering if I should consider it's habit of blocking cap tubes. Parts are expensive for this unit and I really need it to hold up longer then this. Thanks!
Building a Freeze dryer
By kennedyb4 in forum FundamentalsReplies: 15Last Post: 25-07-2009, 06:24 PM -
Compressor failure
By gilbert_c in forum Trouble ShootingReplies: 8Last Post: 27-04-2006, 02:54 PM -
screw compressor failure
By aygul in forum Trouble ShootingReplies: 23Last Post: 09-12-2004, 09:09 AM -
Compressor failure...... cause
By herefishy in forum Technical SpeculationsReplies: 8Last Post: 06-12-2002, 12:15 AM -
oil pressure problems on air dryer
By edge in forum Trouble ShootingReplies: 1Last Post: 16-07-2002, 02:10 PM
