Thread: daikin r22 vrf
    Aug 2005
    uk
    82
    daikin r22 vrf
    been to a site today. old r22 system e4 and u4 fault. found condensor off put on now faulting
    12v dc found being sent inside, this should be more.
    did a bit of searching and found out this system had recently had a fan coil removed. went to where the fan coil was and found 4 2core cables all connected
    this has a central controller on it. i am assuming there is an in and out on f1f2 and also 2 cable sgoing i assume a central controller.
    do i need to tell the outdoor unit there is one less indoor, do i need to adjust the central controller to tell it one has gone
    what do i need to do ta
    Rob
    oh and to top it off the twin split replacing the old indoor unit is over charged by approx 10 gilos. oh joy
    Sep 2009
    Scotland
    374
    Re: daikin r22 vrf
    Is this an R22 G, H or K series? 2 pipe heat pump or 3 pipe heat recovery?
    G series are addressed by rotary switches.
    H & K series will auto address but centralised controller group addresses are programmed by indoor remote
    Aug 2005
    uk
    82
    Re: daikin r22 vrf
    all sorted now thanks tho, it was a 2 pipe system, addressed by a remote on a central controller no remotes
    where the old unit was removed the wires were wrongly connected and also the central controller was still looking for the missing cassette
    also looked at another split while on site, found it 12kg over charged, new install. it had an additional 16kg added on a 70m run!!!!!!!!!!!!!!!
  1. Daikin not working... many problems
    By stankovicv in forum Air Conditioning
    Last Post: 11-12-2010, 09:01 AM
  2. Daikin FDYQ250M
    By carl in forum Air Conditioning
    Last Post: 11-08-2009, 12:56 AM
  3. Daikin AC parts from UK
    By skel00 in forum Air Conditioning
    Last Post: 05-04-2009, 01:24 PM
  4. Fixing Daikin A3 Error
    By Stuffy in forum Air Conditioning
    Last Post: 27-03-2009, 06:02 AM
  5. Getting a price from Daikin....
    By monkey spanners in forum Chit Chat & Service Stories
    Last Post: 17-08-2008, 09:46 PM
